Automatically sign in - When your environment is configured to use SSO with Azure Active Directory, select this option to enable automatic authentication for your account.
Packages configuration - Select the Disable Online Feeds option if you want to disable the Official and Marketplace online feeds for activity packages. Recommended for offline environments.
Automatically Starts Assistant with Windows - Option enabled by default, launches Assistant at Windows startup.
Default download location - The download location for activity packages. Default location is %userprofile%.nuget\packages.
