- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-005 - Hardcoded Activity Properties
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Troubleshooting
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Known issues specific to MV3 extensions
Known issues with MV3 Edge extensions in Studio, including Click activity limitations with javascript: URI click handlers.
Click activity with Simulate fails on specific web page elements
The Click activity with the Simulate input method no longer works on HTML elements that have a click handler with javascript: URI.
In this case, the simulated click will not take effect and no errors will be reported.
This was reported as a Chromium bug. This issue is quite rare as very few HTML elements have click handlers in this form.
Workarounds
Two workarounds are available for this issue:
- Identify the failing Select activity in your workflow and change the input method from Simulate to any other input method (Chromium API, Hardware Events, Window Messages).
- Upgrade to UiPath.UIAutomation.Activities package v22.12 or newer and use the Enable workaround for simulate select with MV3 extension option in Project Settings.
Developer Tools access must be explicitly allowed
Starting with Microsoft Edge 149, Developer Tools access must be explicitly allowed when the UiPath Extension for Edge is installed using Group Policies.
Workarounds
Option 1. Use DeveloperToolsAvailabilityAllowlist and DeveloperToolsAvailabilityBlocklist
The DeveloperToolsAvailabilityAllowlist and DeveloperToolsAvailabilityBlocklist policies let you enable Developer Tools only for the UiPath extension ID, while keeping them disabled for all other extensions. This approach preserves your browser hardening posture and is the recommended option for managed or secured environments.
If the UiPath Extension for Edge is installed using Group Policies, then DeveloperToolsAvailabilityAllowlist and DeveloperToolsAvailabilityBlocklist are automatically configured to enable full functionality of the extension.
You can apply this by running .reg files with the following content or by manually configuring the policies in the registry:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Edge\DeveloperToolsAvailabilityAllowlist]
"1"="chrome-extension://ndmegdjihnhfmljjoaiimbipfhodnbgf"
"2"="chrome-extension://cdfjcmjmgdnojgaojdnefhjjpaijapci"
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Edge\DeveloperToolsAvailabilityBlocklist]
"1"="https://uipath-devtools-blocklist-placeholder.invalid/"
Both DeveloperToolsAvailabilityAllowlist and DeveloperToolsAvailabilityBlocklist policy values must be applied for the changes to take effect. Configuring only DeveloperToolsAvailabilityAllowlist is not sufficient.
When these policy values are correctly configured, full UiPath extension functionality is restored even if DeveloperToolsAvailability=2 (Disallow usage of the Developer Tools).
Option 2. Set DeveloperToolsAvailability to 1
Configure the DeveloperToolsAvailability policy to 1 (Allow usage of the Developer Tools) in your GPO or directly in the Windows Registry on affected machines.
You can apply this by running .reg files with the following content or by manually configuring the policy in the registry:
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Edge]
"DeveloperToolsAvailability"=dword:00000001
The DeveloperToolsAvailability policy has the following possible values:
- 0 - Disallows usage of the Developer Tools on apps and extensions installed by enterprise policy or, since version 114 and if this is a managed user, extensions built into the browser. Allows usage of the Developer Tools in other contexts.
- 1 - Allows usage of the Developer Tools.
- 2 - Disallows usage of the Developer Tools.
If DeveloperToolsAvailability is set to 2, then the following limitations apply:
- The
InjectJSactivity does not work. - The
ChromiumAPIinput method does not work. - The UiPath Extension for Edge is limited to LTS versions of
UiPath.UiAutomation.Activities.
The DeveloperToolsAvailabilityAllowlist / DeveloperToolsAvailabilityBlocklist or the DeveloperToolsAvailability policy values may be overwritten if your organization uses Group Policies for browser extension management, which set different values.
Option 3. Switch to using Chromium Automation instead of the browser extension
This uses the Chromium Automation method instead of the Browser extension to automate the browser.
Chromium Automation is blocked when the DeveloperToolsAvailability Group Policy is set to 2.
The UiPath Web Automation browser window shows a warning
The UiPath Web Automation browser window shows the following warning if ChromeNativeMessaging.exe could not be started:
Cannot communicate with UiPath Platform The native part of the extension is not configured correctly.
Re-install the extension from UiPath Studio.
The Inject Js Script activity can no longer be used to access page variables and code
By default, the Inject Js Script activity can no longer be used to access page variables, such as jQuery $ , or to interact with page code (e.g., window.alert). The Inject Js Script activity won't report an error, but the script will fail to execute and the following error will be reported in the browser DevTools (F12): "Refused to execute inline script because it violates the following Content Security Policy directive."
This is a limitation introduced by the MV3 platform.
Solution
To fix this issue, select the Execution world - Page option from the Inject Js Script activity.
Your existing JavaScript code doesn't require any changes, and by using the Execution world - Page option it will work for both MV2 and MV3 extensions.
Open Browser activity has an insufficient timeout
For MV3 extensions, the browser loads the extension later, after the web pages have loaded. This means that on slower machines, the Open Browser activity from UiPath.UiAutomation.Activities version 22.10 or older can reach the internal timeout of 20 seconds before the extension has started.
Starting with v22.12.0-preview, the internal timeout for the Open Browser activity has been increased from 20 seconds to 60 seconds.
Since you may need to set a longer timeout for the browser startup, it is now configurable from the Use Application/Browser and Open Browser activities. The following project settings have been added:
- UI Automation Classic → Browser → Open browser timeout (seconds)
- UI Automation Modern → Application/Browser → Open browser timeout (seconds)
Additionally, you can configure the timeout through the UIPATH_OPEN_BROWSER_TIMEOUT_SECONDS environment variable. For example, set UIPATH_OPEN_BROWSER_TIMEOUT_SECONDS=120 to use 120 seconds for the activity's timeout.
- Click activity with Simulate fails on specific web page elements
- Workarounds
- Developer Tools access must be explicitly allowed
- Workarounds
- The UiPath Web Automation browser window shows a warning
- The Inject Js Script activity can no longer be used to access page variables and code
- Solution
- Open Browser activity has an insufficient timeout
