- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-005 - Hardcoded Activity Properties
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Troubleshooting
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Check if ComSpec variable is defined correctly
The ComSpec environment variable requirement for ChromeNativeMessaging.exe to launch correctly when automating Microsoft Edge.
The ChromeNativeMessaging.exe process runs under the current user and it uses cmd.exe to start the browser.
If the ComSpec environment variable is missing or has an invalid value, then Microsoft Edge cannot launch the ChromeNativeMessaging.exe.
Furthermore, the administrator may disable the command prompt for some users or configure it to always run with elevated privileges.
Solution
Manually add the correct value for the ComSpec environment variable. This variable is set at Windows installation and must be set to: %SystemRoot%\system32\cmd.exe.
Other workarounds
If the ComSpec environment variable is set correctly but the problem persists, the user may not have permission to run the command prompt. In this case, the ChromeNativeMessaging.exe process cannot be started with cmd.exe running under the current user.
Starting with Chromium 120.0.6090+, a NativeHostsExecutablesLaunchDirectly Group Policy allows admins to turn this on for users in restricted environments (Cloud PCs that forbid cmd.exe, for example).
