- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-005 - Hardcoded Activity Properties
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Troubleshooting
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- Open browser in InPrivate mode
- Open browser with non-default browser profile
- Configure Edge for IE compatibility mode
- Install the extension using Native Host Only method
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Reference for configuring Internet Explorer compatibility mode in Microsoft Edge to support legacy IE infrastructure in browser automations.
Internet Explorer mode in Microsoft Edge provides you with a way to use the legacy infrastructure of IE inside the Chromium-based Microsoft Edge.
To do so, go to the Edge browser > Settings > Default browser > Internet Explorer compatibility > Allow sites to be reloaded in Internet Explorer mode (IE mode) > select Allow from the drop-down menu.
To ensure that the URLs or local files open in a specific compatibility mode (e.g., IE9), you can set the compatibility mode from the Enterprise Site List Manager settings at edge://compat/SiteListManager (see Enterprise Site List Manager in Microsoft Edge).
The IE Mode compatibility must be set to IE9 or later. The default is IE5 and the UiPath.UIAutomation.Activities package does not support that.
