- Getting Started
- Requirements
- Best Practices
- Updating
- Identity Server
- High Availability Add-on
It is important to keep your Identity Server database free from clutter. To do this, we recommend:
- Using SQL Server Maintenance Solution
- Creating a separate database to save data before deleting it
- Deleting old data periodically
- Backing up the database
SQL Server Maintenance Solution is a set of scripts that enable you to run backups, integrity checks, and index and statistics maintenance on all editions of Microsoft SQL Server, starting with the 2005 version. Please see this GitHub project for more information.
Creating an Archive Database
It is recommended that you create a separate database in which to save items before you delete them. This database acts as an archive for the items you may need to store for certain reasons, such as audits.
Create a new database called, for example,
UiPathIdentityArchives:create database UiPathIdentityArchivescreate database UiPathIdentityArchives -
Create the following backup tables:
ArchiveLoginAttemptswith the same structure as theUserLoginAttemptstable:select * into [UiPathIdentityArchives].[dbo].[ArchiveUserLoginAttempts] from [UiPath].[dbo].[UserLoginAttempts] where 1=2select * into [UiPathIdentityArchives].[dbo].[ArchiveUserLoginAttempts] from [UiPath].[dbo].[UserLoginAttempts] where 1=2
Old data is copied to these archives prior to being deleted when using the query below.
Deleting Old Data Periodically
Before running the following script, make sure to adapt them to your environment.
User Login Attempts
To delete login attempts older than 60 days, for example, use the query below. It can be executed manually or scheduled in an SQL Server Job.
declare @NumberOfDaysToKeep int
set @NumberOfDaysToKeep = 60
if OBJECT_ID('[UiPathIdentityArchives].[dbo].[UserLoginAttemps]') = NULL
begin select * into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] from [identity].UserLoginAttempts where 1=2 end
begin transaction
set identity_insert [UiPathIdentityArchives].[dbo].[UserLoginAttemps] on
insert into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] ([Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName])
select [Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName]
from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep
delete from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep
commit transaction
begin transaction
commit transaction
Backing Up the Database
We recommend implementing regular backups of the SQL Server database, such as full weekly or daily incremental backups.
Additionally, we recommend using the DatabaseBackup stored procedure that is created using the script at this location.
