task-mining
Task Mining
連続アップロードを使用した SATA のアップロード
When using the Continous settings, data upload occurs when needed, only if the user is online in the Task Mining desktop application. If you are using Network Shared Folder to store the data locally before data is uploaded, please refer to Using StudyUploader for uploading data.
  • The My Progress from the desktop client settings shows the total data processed, amount uploaded, and pending upload.
If Task Mining isn’t able to upload a file, it retries a fixed number of times, following which it skips uploading that file. Finally, it retries uploading the skipped file after a cooldown period.
If the data upload fails, a notification informs the user, and the resume feature within the application can be used.
Upload status can be viewed on the Task Mining Team page for each user:
注:
アップロードするデータセットには、40,000 件以上のアクションが含まれる必要があります。 最適な結果を得るために、10 万件から 20 万件のアクションを含むデータ セットをアップロードすることをお勧めします。
接続
最新情報を取得
