document-understanding
Document Understanding ガイド
最終更新日時 2026年4月6日
はじめに
The UiPath® Document UnderstandingTM framework facilitates the processing of incoming files, from file digitization to extracted data validation, all in an open, extensible, and versatile environment.
Document Understanding は、様々なドキュメントの種類から情報を抽出するために、異なるアプローチを組み合わることができるよう設計されています。さまざまなドキュメントからデータを抽出する単一のワークフローを作成することで、データ抽出プロセスをできるだけシンプルにします。
Document Understanding フレームワークを使用する前に、以下の Document Understanding フレームワーク コンポーネントを理解しておくことをお勧めします。
  • タクソノミー What documents need to be processed and what data is required from them? Used to define the document types and the pieces of information targeted for data extraction (fields) for each document type, and formalizes this information into a dedicated Taxonomy structure. This metadata information is managed through the Taxonomy Manager.
  • デジタル化 What does this file contain? Used to obtain the textual content and the structure of the incoming document, turning a file into machine-readable content so it can be further processed downstream.
  • ドキュメント分類 What types of documents from the taxonomy are found in this file? Used to automatically determine what document types are found within a digitized file.
  • ドキュメント分類の検証 Is the predicted classification correct? This is how I can review and correct it. Used for assisting in the human validation and correction of the automatic classification and document splitting results.
  • 分類トレーニング Did the human review the data? This is how the robot can learn from it. Used to pass the human validated information back to the classifiers, to use it to improve their future predictions.
  • データ抽出 What data can be found in this particular document? Used to capture the information required for the identified document type, within the given input document and classification page range.
  • データ抽出の検証 Is the extracted information correct? This is how I can review and correct it. Used for assisting in the human validation and correction of the automatically extracted data results.
  • データ抽出トレーニング Did the human review the data? This is how the robot can learn from it. Used to pass the human validated extracted data back to the extractors, to use it to improve their extraction predictions.
  • Data Consumption Used to export the validated data in order to consume it.
  • Metering & Charging Logic Used to explain the consumption of units per page for each available service.
次の図は、Document Understanding フレームワークのコンポーネント間の関連を示しています。
Document Understanding フレームワークを示す図
The Document Understanding framework is found in the UiPath.IntelligentOCR.Activities package. Once the UiPath.IntelligentOCR.Activities package is installed, the Taxonomy Manager wizard appears in the top ribbon of the UiPath Studio. This same package contains all the core document understanding framework activities.
The scope activities (Classify Document Scope, Data Extraction Scope, Train Classifiers Scope, Train Extractors Scope) that are part of the Document Understanding framework allow you to use any document classification and data extraction algorithms that fit your use case and then train these algorithms.
The Document Understanding framework can be used not only with the out-of-the-box classifiers and extractors but also with any custom-built ones. These can be created using the abstract classes from the UiPath.DocumentProcessing.Contracts package and can be implemented as classification or data extraction activities. Custom-built OCR engines can also be created using the abstract classes from the UiPath.OCR.Contracts package.
リソース
Dedicated Document Understanding courses can be found in the UiPath RPA Academy.
UiPath コミュニティ フォーラムは、UiPath の成長著しいユーザー コミュニティから支援を受けられるフォーラムです。
  • リソース
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
