- Démarrage
- Keyword Based Classifier
- FlexiCapture Classifier
- Machine Learning Classifier
- Regex Based Extractor
- Form Extractor
- FlexiCapture Extractor
- Paquets ML
- Pipelines
- Data Manager
- Services OCR
- Apprentissage profond
- Licences
- Référence (Reference)
- UiPath.Abbyy.Activities
- UiPath.OCR.Activities
- UiPath.OCR.Contracts
- UiPath.OmniPage.Activities
- UiPath.PDF.Activities
Fournit une étendue pour les activités d'extraction vous permettant de les configurer en fonction des types de documents définis dans votre taxonomie. Vous trouverez plus de détails ici.
Enables you to create and use a custom Regular Based Expression to extract information from a document. More details here.
Form Extractor
Extracts, matches, and reports the required information by taking into consideration the words' position inside the document. More details here.
Analyses, extracts, matches, and reports the required information from a document by considering the words position, including handwritten and signed fields. More details here.
Enables data extraction from documents using machine learning models provided by UiPath. More details here.
Enables you to extract data from a document based on a set of FlexiCapture definition files. More details here.
