- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
Automation Suite API guide
Allocate Licenses to a Group
As an organization admin, use this endpoint to allocate licenses to a group. To do that, you need to create an external application, with the scope PM.License.Write.
Find out how to create an external application.
API Endpoint
PUT https://{yourDomain}/{organizationName}/lease_/api/account/{accountId}/user-license/group/{groupId}
Request Headers
To obtain the {access_token}, make sure to authenticate through the ROPC method described here.
Path Parameters
| Path param | Data type | Description |
accountId (required) | String | The ID of the organization in which your tenant resides. |
groupId (required) | String | The ID of the group you want to allocate licenses to. You can retrieve this ID by following these steps. |
Request Body
The request body contains the array of license codes for various products and their corresponding quantity.
"userBundleCodes": ["string"]
- To see the available user bundle codes you may use in the request body, check out the user license codes.
- You may allocate as many licenses as the organization has purchased.
Responses
200 OK
Returns the allocated group licenses.
404
No account license is allocated for the indicated organization.
409
The license allocation is not allowed because it exceeds the account license quantities.
Example Request
Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}is:https://{yourDomain}/{organizationName}. - Your
{access_token}is:1234(for length considerations). - The
{accountId}of the tenant that needs license allocation is:song-one - The
{groupId}is:group-01. - You want to allocate user licenses to the group as follows:
- Automation Developers - Named user (the license code is
RPADEVPRONU) - Insights Designer (the license code is
IDU) - Citizen Developer - Multiuser (the license code is
CTZDEVCU)
The call should resemble the following example (cURL):
curl --location --request POST 'https://https://{yourDomain}/{organizationName}/lease_/api/account/1234/user-license/group/group-01' \
--header 'Content-Type: application/json' \
--data-raw '{
"userBundleCodes": ["RPADEVPRONU", "IDU", "CTZDEVCU"],
"useExternalLicense": false
--data-raw '{
Here's the response body for a successful license allocation:
"groupId": "string",
"organizationId": "string",
"useExternalLicense": false,
"string"
"string"
