  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Automation Suite API guide
Last updated Feb 24, 2025
Allocate Licenses to a Tenant
As a host admin, use this endpoint to allocate licenses to a tenant, based on the tenant ID.
Important: To allocate licenses to organizations and tenants, you need to authenticate using the host credentials.
API Endpoint
PUT https://{yourDomain}/lrm/api/account/{accountId}/service-license/{serviceScopeId}/{serviceType}
Note: To allocate licenses to every enabled service of the tenant, you need to make a separate API call for each service.
Request Headers
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
Note: To obtain the {access_token}, make sure to authenticate through the ROPC method described here.
Path Parameters
Path param
Data type
accountId
(required)
String
The ID of the organization in which your tenant resides.
serviceScopeId
(required)
String
The ID of the tenant you want to allocate licenses to.
serviceType
(required)
String
The service type.
Request Body
The request body contains the array of license codes for various products and their corresponding quantity.
      "tenantName": "string",
      "products":
          { "code": "string", "quantity": 0 }
      "products":
Note:
  • To see the available license codes you may use in the request body, check out License codes.
  • You may allocate as many licenses as the organization has purchased.
Responses
200 OK
Returns the allocated service licenses.
  "accountId": "string",
  "serviceScopeId": "string",
  "serviceType": "string",
  "license": {
    "licenseCode": "string",
    "bundleCode": "string",
    "subscriptionCode": "string",
    "licenseStatus": "string",
    "startDate": 0,
    "endDate": 0,
    "gracePeriod": 0,
    "products": [
        "code": "string",
        "quantity": 0,
        "type": "string",
        "features": [
            "code": "string",
            "type": "string",
            "value": "string"
    "templates": [
        "productCode": "string",
        "products": [
            "code": "string",
            "type": "string"
    "payload": "string",
    "boonLicenseCode": "string"
  "userLicensingEnabled": true,
  "accountLicenseCode": "string"
  "license": {
    "startDate": 0,
    "endDate": 0,
    "gracePeriod": 0,
    "products": [
        "code": "string",
        "quantity": 0,
        "type": "string",
        "features": [
            "code": "string",
            "type": "string",
            "value": "string"
    "templates": [
        "products": [
            "code": "string",
            "type": "string"
404
No account license is allocated for the indicated organization.
409
The license allocation is not allowed because it exceeds the account license quantities.
Example Request
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://tom-jones-server.com
  • Your {access_token} is: 1234 (for length considerations).
  • The {accountId} of the tenant that needs license allocation is: y-y-y-delilah
  • The {serviceScopeId} is: y1968. The tenant has the Document Understand service enabled.
  • You want to allocate product licenses to the organization as follows:
The call should resemble the following example (cURL):
curl --location --request POST 'https://tom-jones-server.com/lrm/api/account/y-y-y-delilah/service-license/y1968/?????' \
--header 'Content-Type: application/json' \
--data-raw '{
    "productQuantities":
          { "code": "UNATT", "quantity": 5 },
          { "code": "NONPR", "quantity": 4 },
          { "code": "TIE", "quantity": 2 }
}'curl --location --request POST 'https://tom-jones-server.com/lrm/api/account/y-y-y-delilah/service-license/y1968/?????' \
--data-raw '{
Here's the response body for a successful license allocation:
  "accountId": "y-y-y-delilah",
  "serviceScopeId": "y1968",
  "license": {
    "startDate": 0,
    "endDate": 0,
    "gracePeriod": 0,
    "products": [
        "code": "string",
        "quantity": 0,
        "type": "string",
        "features": [
            "code": "string",
            "type": "string",
            "value": "string"
    "templates": [
        "products": [
            "code": "string",
            "type": "string"
  "license": {
    "startDate": 0,
    "endDate": 0,
    "gracePeriod": 0,
    "products": [
        "code": "string",
        "quantity": 0,
        "type": "string",
        "features": [
            "code": "string",
            "type": "string",
            "value": "string"
    "templates": [
        "products": [
            "code": "string",
            "type": "string"
  • API Endpoint
  • Request Headers
  • Path Parameters
  • Request Body
  • Responses
  • 200 OK
  • 404
  • 409
  • Example Request
