  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Automation Suite API guide
Last updated Feb 28, 2026
Delete Specific Group
Deletes the specified group in an organization, based on the organization and group ID.
API Endpoint
DELETE https://{yourDomain}/{organizationName}/identity_/api/Group/{partitionGlobalId}/{groupId}
Scopes
Requires the following scopes:
  • PM.Group
  • PM.Group.Write
Request Headers
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Path Parameters
Path paramData typeDescription
partitionGlobalId (required)StringThe ID of the organization you want to delete the group from.
groupId (required)StringThe ID of the group you want to delete.
Responses
204 Success
The indicated group is deleted from the organization.
Example Request
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}/{tenantName}/
  • Your {access_token} is: 1234 (for length considerations).
  • The {partitionGlobalId} is: magic-7
  • The {groupId} is: 2512
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/Group/magic-7/2512' \
  • API Endpoint
  • Scopes
  • Request Headers
  • Path Parameters
  • Responses
  • 204 Success
  • Example Request
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
