2022.4
Automation Suite API guide
  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Delete Specific Group
Deletes the specified group in an organization, based on the organization and group ID.
API Endpoint​
DELETE https://{yourDomain}/{organizationName}/identity_/api/Group/{partitionGlobalId}/{groupId}
Scopes​
Requires the following scopes:
  • PM.Group
  • PM.Group.Write
Request Headers​
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Path Parameters​
Path paramData typeDescription
partitionGlobalId
(required)
StringThe ID of the organization you want to delete the group from.
groupId
(required)
StringThe ID of the group you want to delete.
Responses​
204 Success​
The indicated group is deleted from the organization.
Example Request​
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}/identity_
  • Your {access_token} is: 1234 (for length considerations).
  • The {partitionGlobalId} is: 3fa85f64-5717-4562-b3fc-2c963f66afa6
  • The {groupId} is: 2512
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/identity_/api/Group/3fa85f64-5717-4562-b3fc-2c963f66afa6/2512' \
  • API Endpoint​
  • Scopes​
  • Request Headers​
  • Path Parameters​
  • Responses​
  • 204 Success​
  • Example Request​
Connect
Stay updated
