Automation Suite API guide
- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
- Get All Groups
- Get Specific Group
- Delete Specific Group
- Create a New Local Group
- Update Group
Deletes the specified group in an organization, based on the organization and group ID.
API Endpoint
DELETE https://{yourDomain}/{organizationName}/identity_/api/Group/{partitionGlobalId}/{groupId}
Scopes
Requires the following scopes:
- PM.Group
- PM.Group.Write
Request Headers
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Path Parameters
| Path param | Data type | Description |
partitionGlobalId(required) | String | The ID of the organization you want to delete the group from. |
groupId(required) | String | The ID of the group you want to delete. |
Responses
204 Success
The indicated group is deleted from the organization.
Example Request
Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}is:https://{yourDomain}/{organizationName}/identity_ - Your
{access_token}is:1234(for length considerations). - The
{partitionGlobalId}is:3fa85f64-5717-4562-b3fc-2c963f66afa6 - The
{groupId}is:2512
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/identity_/api/Group/3fa85f64-5717-4562-b3fc-2c963f66afa6/2512' \
