- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- About accounts and groups
- Managing Accounts and Groups
- Managing access
- External applications
- Notifications
- Logging
- Troubleshooting
Organization administrators can view, add, edit, or remove accounts and groups for the Automation Suite organization from the Admin > Accounts and Groups page at the organization level.
Adding Groups
You can add new groups if you want to define a custom mix of roles and license allocation rules to use for a particular group of accounts. For example, the ones needed by your colleagues in the Accounting department to use Automation Suite.
- In the Users and Groups page, navigate to the Groups tab.
- Click Add Group. The Add Group window is displayed.
- Fill in the Name field.
- On the Group Members field, add users to the group. Only users that have been invited to your organization beforehand are displayed here.
Unlike default user groups, custom groups need to be added manually to your services to allocate roles.
Adding accounts
Adding User Accounts
Go to Admin > Accounts and Groups and select the Users tab.
Click Add User. The Add User panel opens from the right of the window.
Fill in the fields with the user's details.
- If you are integrated with an external directory, the password is not required and, if system email notifications are set up, the user receives an email with their account details and can set their own password at first login.
- If not, you must set a password for the account. The user will need the email address (or username) and password to log in to Automation Suite.
If an External Provider integration is enabled for authentication, you can switch on the Always allow basic authentication for this user toggle if you want this user to also be able to log in using their local account.
Under Group Membership, select the checkboxes for the groups to which you want to add the user.
If your groups are properly set up, the user should already have the access they need to start working in Automation Suite.
Click Save to add the account.
The panel closes and the new account is available in the list of user accounts.
Adding Robot Accounts
For more information about this type of account, when and why to use it, see .
Go to Admin > Accounts and Groups and select the Robot accounts tab.
In the top right, click Add Robot Account.
The Add Robot Account panel opens at the right of the page.
In the Name field, type a descriptive name for the account.
Important:Choose wisely. You cannot change the name of the robot account later. If you need to rename it, you must delete the account and create a new one with a new name.
Optionally, under Group Membership, select the checkbox for groups to which you want to add the account.
Adding the account to one or more groups means it inherits any roles, user licenses, or robot settings defined for the group.
Click Add.
A success message appears at the top of the panel and further guidance is displayed.
The robot account is added and is now visible on the Robot accounts page. It is also added to the groups you selected.
Continue the setup of the robot account in UiPath Orchestrator as you would set up a user account for unattended use: Unattended Setup.
Adding Accounts to Groups
Adding an account - either user or robot - to a group means the account inherits the roles and licenses assigned to the group.
You can check roles for a group from Orchestrator and you can check license allocation rules for the group from the Licenses page.
- Go to Admin > Users and Groups and select the Groups tab.
- At the right end of the group row, click
Edit. - In the Group Members field, type to search for a user or robot account.
- Select the account from the list of results to add it to the group.
- Click Save.
Editing an Account or Group
You edit accounts and groups in the same way:
- Go to Admin > Users and Groups and select the appropriate tab.
- At the right end of a row, click
Edit. - Make changes as needed.
- Click Save.
Checking the roles for an account or group
You can check the roles assigned to an account or group from UiPath Orchestrator.
Go to Tenant > Manage Access > Assign roles and select Check roles & permissions. You can search for any account or group to view the assigned roles.
In the Check roles window, each permission is listed on a per-folder basis. Adjacent to each permission, you can view whether it has been explicitly assigned or inherited from the tenant.
Removing an Account or Group
- Go to Admin > Accounts and Groups, and select the appropriate tab.
- At the right end of the row, click
Remove. - Confirm the action in the confirmation dialog.
Effects of removal
For accounts: After the account is removed, the user or service can no longer log in to Automation Suite.
For groups, after the group is removed:
- Any roles, licenses, or robot setup for the removed group are revoked from all user accounts that belonged to the group.
- If a user account that was a part of the removed group does not have any other roles (either directly assigned or inherited from other groups), they can still log in, but they have read-only rights.
