- Getting started
- Host administration
- Organizations
- Tenants and services
- About tenants
- Managing tenants
- Managing services
- Managing tags
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Notifications
- Logging
- Troubleshooting
Managing tenants
For examples on how you can use tenants to create separation of resources within your organization, refer to Examples of platform modelling.
Adding tenants
To create a new tenant:
Go to Admin.
In the left panel, select + next to the Tenants header to add a tenant:
The Create a new tenant wizard opens on the first step, General.
Enter a name for your tenant in the Tenant Name field.
You can enter up to 32 alphabetical or numeric characters, starting with a letter. No spaces or special characters are allowed.
Important:You can change the tenant name later, but there are consequences.
Refer to Changing the tenant name.
(Optional) From the Color list to the right of the Tenant Name field, choose a color to show in the header when this tenant is selected.
This can help users easily tell which tenant they're currently working in:
If you want to use this tenant as a canary tenant, select Use as a canary environment.
For more information, refer to .
Note:If you already have a canary tenant, even if it is currently disabled, you cannot select the checkbox to create another canary tenant.
From the Tenant Region list, choose the region for hosting your service data for this tenant.
Important:You cannot change the tenant region yourself after you create the tenant. If you need to change it later, you must open a Support ticket.
When a tenant and associated data are moved to a new region, the tenant ID and folder ID are changed. You must update your projects with the new tenant and folder IDs.
Select Next to proceed to the next step.
Select the checkboxes for the services that you want to make available within the new tenant.
The Orchestrator service is mandatory. Other services are only available if you have free licenses for the service.
Note:If a service is only available in a different region than the selected tenant region, the region where that particular service will be hosted is displayed on the card for the service. For more informations, refer to Tenant and service regions.
On the License Allocation step, we automatically fill in the license quantities to allocate all your free licenses to the tenant.
If you want to keep some of your available licenses for other tenants, reduce the quantity for each license type to the amount you want to allocate to this tenant.
The number of licenses you have available is displayed under each license type. This is the number of licenses you have before creating this tenant and out of which you can allocate to this tenant.
Select Create to close the wizard and create the tenant.
The new tenant is added to the Tenants panel on the left.
The loading icon is displayed while tenant provisioning is in progress.
After the icon disappears:
- The tenant and its services are ready for use.
- The tenant is available to users from the tenant picker in the top right of the page, but they only have read-only access.
Next steps: To be able to work in the tenant, you or a service administrator must assign roles and licenses for the services in the new tenant to users. For more information, refer to:
Editing tenants
When editing tenant settings, you can change the name, color, enable, disable, or delete the tenant.
Changing the tenant name or color
Go to Admin and select the tenant in the panel on the left.
Select Settings.
The Settings page for the selected tenant opens.
Edit the tenant name if needed.
Important:Changing a tenant's name disconnects your Robots and Mobile Orchestrator users, and invalidates any pending user invites. Refer to Impact of Changing Tenant Names.
From the list to the right of the name, select a different header color for the tenant, if needed.
Select Save Changes at the bottom of the page.
A confirmation message appears in the top right of the screen.
Impact of changing tenant names
Changing the name of any of your tenants greatly impacts your previous UiPath service configurations:
- Robots configured at Orchestrator services level are disconnected. Reconnect your robots, entering the new URLs.
- Service URLs previously bookmarked don't work anymore. Send your users the new URLs.
- Mobile Orchestrator users are disconnected. Send them the new service URLs to connect again.
Enabling or disabling a tenant
Disabled tenants remain visible to organization administrators in the Tenants panel of the Admin page, but the tenant and its services are no longer available to users. Also, the licenses that were allocated to the tenant are released and returned to the organization's pool of licenses.
All data for the services is kept. You can later enable the tenant to access its services again.
Select Settings.
Under Disable Tenant, select Enable or Disable, depending on the current state of the tenant.
A warning dialog opens.
In the dialog, select Enable or Disable to proceed.
A loading icon is shown next to the tenant in the Tenants panel on the left while the change is being processed.
- If you disabled the tenant, Disabled appears to its right and the tenant and its services are no longer available to users.
- If you enabled the tenant, it is now restored as it was before being disabled. All licenses that it used before are also re-allocated if they were available in the organization pool. The tenant and its services are now available for use.
Deleting a tenant
When deleting a tenant, you remove the tenant from your organization and also delete all of its services and any service data.
After deleting a tenant, all its licenses are freed up and available for you to allocate to other tenants.
If any processes are being executed in the tenant's Orchestrator service, you cannot delete the tenant.
Select Settings.
Under Delete permanently, select Delete, depending on the current state of the tenant.
The Delete Tenant dialog opens.
In the field, enter the tenant name, exactly as it is shown, including the letter case, and then select Delete.
A loading icon is displayed next to the tenant in the Tenants panel while the deletion is in progress. When complete, the tenant is removed from the Tenants panel.
Editing tenant licenses
In Admin > Tenant > Licenses, you can view information about the licenses currently allocated to each tenant.
To change the license quantities, select Edit allocation in the top right corner.
For more information, refer to Allocating licenses to tenants.
