- First Time Configuration
- Host Administration
- Organization Administration
- Accounts and Roles
- Licensing
Host Authentication and Security Settings
As a system administrator, you can choose the authentication and related default security settings for your entire Automation Suite installation. These settings are inherited by all organizations as default.
This article walks you through the steps for configuring global authentication and security settings. If you want to configure organization-level settings, i.e., settings that apply to one organization, see documentation on organization-level authentication settings.
Automation Suite allows you to configure an external identity provider to control how your users sign in. The following table provides an overview of the different host-level external providers available:
External Provider Integration |
Authentication |
Directory Search |
Administrators Provisioning |
Administrators can use SSO with Windows Authentication using the Kerberos protocol |
Administrators can search for users from the Active Directory |
For a user to be able to login, either the user or a group that the user is a member of should already be added to Automation Suite. Active Directory users and groups are available in Automation Suite through directory search. | |
Administrators can use SSO with Azure AD using the OpenID Connect protocol |
Not supported |
Users must be manually provisioned into the Automation Suite. with an email address matching their Azure AD account. | |
Users can use SSO with Google using the OpenID Connect protocol |
Not supported |
Users must be manually provisioned into the Automation Suite organization with an email address matching their Google account. | |
Users can use SSO with any Identity Provider that supports SAML |
Not supported |
Users must be manually provisioned into the Automation Suite organization with a username/email/external provider key (as configured in their external identity provider configuration) matching their SAML account. |
Basic authentication refers to signing in with the username and password of a local account.
If basic authentication is restricted, your users can only log in with their directory account, as defined in the external identity provider. Otherwise, users can log in with both their local accounts, if any, and their directory accounts.
Configuration levels and inheritance
This option can be configured:
at the host level, as described below.
When set at the host level, the setting applies to all organizations and all their accounts, except if the basic authentication setting at the organization or account level was not explicitly set differently.
for system administrator accounts, as described below.
Even when all organizations are restricted from using basic authentication, you can allow system administrators only to bypass this restriction.
at the organization level, as described in Configuring authentication and security.
If set at the organization level, the organization-level setting overrides the host-level setting for only that organization. The setting for an organization applies to all accounts that belong to that organization, except accounts for which basic authentication is set differently at the account level.
at the account level, as described in Adding accounts.
If set at the account level, the account-level setting overrides the host-level and organization-level basic authentication setting for only that account.
Setting Basic Authentication at the Host Level
When set at the host level, the setting applies to all organizations and all their accounts. Set it according to the preference or recommendation across your company.
For exceptions, basic authentication can also be set at the organization or account level where you want this setting to apply differently.
To allow or restrict basic authentication for all organizations and all accounts:
Recovering From Lock Out
When basic authentication is disabled, it is possible to get locked out if you lose access to your directory account.
https://<FQDN>/host/orchestrator_/account/hostlogin
and log in using your basic authentication credentials.
To configure security options for your Automation Suite installation, log in to the host portal and go to Security Settings. In the Security section, you can update the following settings as needed.
Field |
Description |
Special characters |
Select to force users to include at least one special character in their password. By default, this checkbox is not selected. |
Lowercase characters |
Select to force users to include at least one lowercase character in their password. By default, this checkbox is selected. |
Uppercase characters |
Select to force users to include at least one uppercase character in their password. By default, this checkbox is not selected. |
Digits |
Select to force users to include at least one digit in their password. By default, this checkbox is selected. |
Minimum password length |
Specify the minimum number of characters a password should contain. By default, it is 8. The length cannot be smaller than 1 or greater than 256 characters. |
Days before password expiration |
Specify the number of days for which the password is available. After this period, the password expires and needs to be changed. The minimum accepted value is 0 (the password never expires), and the maximum is 1000 days. |
Number of times a password can be reused |
The minimum accepted value is 0 (never allow reusing a password), while the maximum is 10. |
Change password on the first login |
If set to Required, users that log in for the first time must change their password before being allowed to access Automation Suite. If set to Not required, users can log in and continue to use the admin-defined password until it expires. |
Field |
Description |
Enabled or Disabled toggle |
If enabled, locks the account for a specific amount of seconds after a specific amount of failed login attempts. This also applies to the password change feature. |
Account lockout duration |
The number of seconds a user needs to wait before being allowed to log in again after exceeding the Consecutive login attempts before lockout. The default value is 5 minutes. The minimum accepted value is 0 (no lockout duration), and the maximum is 2592000 (1 month). |
Consecutive login attempts before lockout |
The number of failed login attempts allowed before the account is locked. The default value is 10 attempts. You can set a value between 2 and 10. |
