ai-center
2022.4
AI Center Installation Guide
Requirements
Overview​
Note:
Before choosing your deployment profile, see Supported use cases for single-node and multi-node installations.
What you needRequirementsConfigurationInstallation
One Linux machine
(RHEL 8.2, 8.3, 8.4, 8.5, 8.6)
Multi-node machine requirementsConfiguring the machines
SQL Server
(MS SQL 2016, 2017, 2019 - Enterprise and Standard)
-Configuring MS SQL Server-
DNS--
Load balancer-Configuring the load balancer-
Multi-node machine requirements​
This is the only configuration supported for production deployments.
BundleMinimumRecommended
Node countAt least 3 server nodes. There must be an odd number of server nodes in a cluster to have increased fault tolerance
Any number of agent nodes.
(v-)CPU total48 (v-)CPU64 (v-)CPU
Minimum (v-)CPU per node16 (v-)CPU16 (v-)CPU
RAM total96 GiB144 GiB
Cluster disk for each node256 GiB SSD
Min IOPS: 1100
256 GiB SSD
Min IOPS: 1100
Data disk for each server node2 TiB SSD
Min IOPS 1100
2 TiB SSD
Min IOPS 1100
etcd disk for each server node16 GiB SSD
Min IOPS: 240
16 GiB SSD
Min IOPS: 240
UiPath Bundle Disk
(For offline installation only, on the first server node)
512 GiB SSD
Min IOPS: 1100
512 GiB SSD
Min IOPS: 1100
Note:
Following the minimum requirements above is enough for three HA skills (two replicas) and one pipeline running in parallel with the default configuration.
Additional agent node with GPU support for Document Understanding​
BundleRequirement
(v-)CPU8 (v-)CPU
RAM52 GiB
Cluster disk256 GiB SSD
Min IOPS: 1100
Data diskN/A
GPU RAM11 GiB
Advanced storage and compute requirements​
UseCPURAM (GiB)GPU
Hardware usage right after install30 (for minimum configuration)
33 (for recommended configuration)
480
Minimum for serving (ML Skill, one replica)0.620
Minimum for Training (Pipeline)140
Document Understanding model Serving (ML Skill, one replica)140
Document Understanding model Training2241
Note:
Trainable Document Understanding ML Packages provided by UiPath will work on both CPU or GPU. For 2021.10, training on GPU is at least 5 times slower than training on CPU. Also, please know that training on CPU is only supported for datasets up to 5000 pages in size. Validation Station retraining loop is not supported on deployments without a GPU, due to the fact that dataset sizes increase too fast and may hit a compute wall with CPU very quickly. If you run UiPath Document OCR Local Server on AI Center to process more than 2 million pages of documents a year, GPU is strongly recommended for a better product experience.
  • Overview​
  • Multi-node machine requirements​
  • Additional agent node with GPU support for Document Understanding​
  • Advanced storage and compute requirements​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
