- Getting Started
- Network requirements
- Single-node requirements and installation
- Multi-node requirements and installation
- Accessing AI Center
- Provision an AI Center tenant
- Updating Orchestrator and Identity Server certificates
- Resizing PVC
- Adding a new node to the cluster
- ML packages offline installation
- Configuring the cluster
- Configuring the FQDN post-installation
- Backing up and restoring the cluster
- Using the monitoring stack
- Setting up a Kerberos authentication
- Provisioning a GPU
- Using the configuration file
- Node scheduling
- Migration and upgrade
- Basic Troubleshooting Guide
What it is
The Installation and Upgrade guide offers a centralized location for instructions on how to install, upgrade, configure, and troubleshoot standalone UiPath products. It describes the infrastructure and architecture of these products and provides guidance on how to get them up and running.
Whom it addresses
This guide addresses system administrators with technical knowledge and expertise.
What it includes
This guide documents strictly standalone products.
The AI Center standalone installation uses the same installer as Automation Suite. Some pages from the Installing AI Center standalone section can lead to the corresponding page in the Automation Suite. In this situation, the steps are the same in both situations and there are no particularities in the specific procedure for AI Center.
Make sure that you follow the procedure suited to your needs.
