- Overview
- UI Automation
- Applications and technologies automated with UI Automation
- UI Automation Classic Project Settings
- UI Automation Modern Project Settings
- UI-ANA-016 - Pull Open Browser URL
- UI-ANA-017 - ContinueOnError True
- UI-ANA-018 - List OCR/Image Activities
- UI-DBP-006 - Container Usage
- UI-DBP-013 - Excel Automation Misuse
- UI-DBP-030 - Forbidden Variables Usage In Selectors
- UI-PRR-001 - Simulate Click
- UI-PRR-002 - Simulate Type
- UI-PRR-003 - Open Application Misuse
- UI-PRR-004 - Hardcoded Delays
- UI-REL-001 - Large Idx in Selectors
- UI-SEC-004 - Selector Email Data
- UI-SEC-010 - App/Url Restrictions
- UI-USG-011 - Non Allowed Attributes
- SY-USG-013 - Private File Invoke
- SY-USG-014 - Incorrect Execution Template Placeholders
- UX-SEC-010 - App/Url Restrictions
- UX-DBP-029 - Insecure Password Use
- UI-PST-001 - Audit Log Level in Project Settings
- UiPath Browser Migration Tool
- Computer Vision Recorder
- Activate
- Anchor Base
- Attach Browser
- Attach Window
- Block User Input
- Call Transaction
- Callout
- Check
- Click
- Click Image
- Click Image Trigger
- Click OCR Text
- Click Picture on Screen
- Click Text
- Click Toolbar Button
- Click Trigger
- Close Application
- Close Tab
- Close Window
- Context Aware Anchor
- Copy Selected Text
- Element Exists
- Element Scope
- Expand ALV Hierarchical Table
- Expand ALV Tree
- Expand Tree
- Export UI Tree
- Extract Structured Data
- Find Children
- Find Element
- Find Image
- Find Image Matches
- Find OCR Text Position
- Find Relative Element
- Find Text Position
- Get Active Window
- Get Ancestor
- Get Attribute
- Get Event Info
- Get From Clipboard
- Get Full Text
- Get OCR Text
- Get Password
- Get Position
- Get Source Element
- Get Text
- Get Visible Text
- Go Back
- Go Forward
- Go Home
- Google Cloud Vision OCR
- Hide Window
- Highlight
- Hotkey Trigger
- Hover
- Hover Image
- Hover OCR Text
- Hover Text
- Image Exists
- Indicate On Screen
- Inject .NET Code
- Inject JS Script
- Invoke ActiveX Method
- Key Press Trigger
- Load Image
- Maximize Window
- Microsoft Azure Computer Vision OCR
- Microsoft OCR
- Minimize Window
- Monitor Events
- Mouse Trigger
- Move Window
- Navigate To
- OCR Text Exists
- On Element Appear
- On Element Vanish
- On Image Appear
- On Image Vanish
- Open Application
- Open Browser
- Read Statusbar
- Refresh Browser
- Replay User Event
- Restore Window
- SAP Login
- SAP Logon
- SAP Session Attributes Change Trigger
- Save Image
- Select Dates in Calendar
- Select Item
- Select Menu Item
- Select Multiple Items
- Send Hotkey
- Set Clipping Region
- Set Focus
- Set Text
- Set To Clipboard
- Set Web Attribute
- Show Window
- Start Process
- System Trigger
- Table Cell Scope
- Take Screenshot
- Tesseract OCR
- Text Exists
- Tooltip
- Type Into
- Type Secure Text
- Use Foreground
- Wait Attribute
- Wait Element Vanish
- Wait Image Vanish
- Application Event Trigger
- Check/Uncheck
- Check App State
- Check Element
- Click
- Click Event Trigger
- Close Popup
- Drag and Drop
- Extract Table Data
- For Each UI Element
- Get Attribute
- Get Browser Data
- Get Text
- Get URL
- Go to URL
- Highlight
- Hover
- Inject Js Script
- Keyboard Shortcuts
- Keypress Event Trigger
- Mouse Scroll
- Navigate Browser
- Select Item
- Set Browser Data
- Set Runtime Browser
- Set Text
- Take Screenshot
- Type Into
- Use Application/Browser
- Perform browser search and retrieve results using UI Automation APIs
- Web Browsing
- Find Images
- Click Images
- Trigger and Monitor Events
- Create and Override Files
- HTML Pages: Extract and Manipulate Information
- Window Manipulation
- Automated List Selection
- Find and Manipulate Window Elements
- Manage Text Automation
- Load and Process Images
- Manage Mouse Activated Actions
- Automate Application Runtime
- Automated Run of a Local Application
- Browser Navigation
- Web Automation
- Trigger Scope Example
- Mobile Automation
- Release notes
- Project compatibility
- Get Log Types
- Get Logs
- Get Page Source
- Get Device Orientation
- Get Session Identifier
- Install App
- Manage Current App
- Manage Other App
- Open DeepLink
- Open URL
- Mobile Device Connection
- Positional Swipe
- Press Hardware Button
- Set Device Orientation
- Take Screenshot
- Take Screenshot Part
- Element Exists
- Execute Command
- Get Attribute
- Get Selected Item
- Get Text
- Set Selected Item
- Set Text
- Swipe
- Tap
- Type Text
- Draw Pattern
- Terminal
![](https://docs.uipath.com/_next/static/media/grid.05ebd128.png?w=3840&q=100)
Use Project Settings to configure changes at the project level. These global settings impact all activities in the package that have the properties listed below. For more information, see Configuring Activity Project Settings.
To configure the UI Automation Modern project settings, follow these steps:
- In the Project panel, go to Project Settings.
- Navigate to Activities Settings > UI Automation Modern.
- Modify the settings according to what you want to change.
- Click OK to save changes.
You can reset all settings to their default values or copy all values between the debug and production fields using the Bulk Actions drop-down menu at the top of the window.
The settings below apply to all of the UI Automation Modern activities.
Property name | Description |
Delay after (seconds) | Delay time between the current activity and the next activity. |
Delay before (seconds) | Delay time between the previous activity and the current activity. |
Timeout (seconds) | How long to wait for the current activity to be executed before throwing an error. |
Wait for page load | Before performing the action, wait for the application to become ready to accept input. The following options are available:
Capture screenshots | Dictates if screenshots are captured at design time by all the activities that support this feature. If the setting is set to false, the Remove informative screenshot option from the context menu is disabled. |
Show closest matches in the 'Element not found' error message | If set to True, ten suggestions of the closest selector matches that can be used to replace the faulty selectors are displayed in the logs. |
Alter disabled element | If set to True, the Select Item action is executed even if the specified UI element is disabled. This property does not apply if the Input Mode property is set to Hardware Events. |
Wait for primary targeting method until timeout | If set to True, this setting allows the primary targeting method to consume its full timeout until any fallback targeting method can be used. |
Ask user on runtime error | If set to True, a prompt is displayed allowing you to decide what to do next and continue the automation instead of just stopping the execution. |
The settings below apply to indicated targets and anchors for desktop applications.
Input mode | Select how to execute the action:
Strict selector | If set to True, uses the Strict selector method. |
Fuzzy selector | If set to True, uses the Fuzzy selector method. |
Computer Vision | If set to True, uses the Computer Vision method. The default value is True. |
Image | If set to True, uses the Image
targeting method.
Note: This method is only used for the Check App State activity if the other methods are disabled. |
Ignore selectors with IDX / tableRow / tableCol | Disable the full selector if the target selector has a tableRow , tableCol , or an idx attribute with a value higher than 1 and anchors exist.
Generate native WPF selectors (Preview) | Enable the generation of native WPF selectors for WPF applications. |
The settings below apply to indicated targets and anchors for web applications.
Input mode for Edge, Chrome | Select how to execute the action:
Input mode for Firefox, IE, Edge in IE Mode | Select how to execute the action:
Image | If set to True, uses the Image targeting method.
The settings below apply to indicated targets and anchors for Java applications.
targeting method.
The settings below apply to indicated targets and anchors for SAP.
Fuzzy selector | If set to True, usesthe Fuzzy selector method. |
Computer Vision | If set to True, uses the Computer Vision method. The default value is False. |
targeting method.
Settings for all the activities that have the Verify Execution feature.
Timeout (seconds) | The amount of time (in seconds) to wait for the verification element to appear/disappear. If Retry is set to True , the action is performed again, followed by the verification, for the duration specified in the Timeout property. |
Retry | If set to True, the action is retried for the duration of the activity timeout, if the expected outcome was not achieved. By default, this check box is selected. |
Always auto-verify typed text | If set to True, any action that types text is verified using the Verify Execution feature. |
Display verification for Click, Hover, Keyboard Shortcuts activities | If set to True, the Click, Hover, and Keyboard Shortcuts activities are always verified using the Verify Execution feature. |
The settings below apply to the Use Application/Browser activity.
Open | In which cases to open the target application before executing activities in it. The following options are available:
Close | In which cases to close the target application after executing activities in it. The following options are available:
Resize window | Defines whether the application/browser is resized when initialized.
Runtime browser | Specfies which browser you want to use at runtime. The following options are available:
WebDriver Mode | Indicates how the WebDriver is used when opening a new browser session. The following options are available: Disabled - Disables the use of WebDriver. WithGUI - The GUI of the browser is displayed. Headless - The browser is launched silently, with no GUI. |
Automatically download WebDriver | If set to True, specifies whether you want to automatically download the WebDriver. |
User data folder mode | The user data folder mode you want to set. It is used to start the browser with a specific user data folder.
User data folder path | The path to the user data folder that the browser uses. |
Open browser timeout (seconds) | Configure the browser startup timeout. |
The settings below apply to the Type Into and Keyboard Shortcuts activities.
Type Into - Click before typing | Whether to click the specified UI element before typing the text, and the type of click to perform. The following options
are available:
Type Into - Empty field | Whether to delete the existing content before typing the text, and how to clear the field. The following options are available:
Type Into - Delay between keys (seconds) | Delay time between consecutive keystrokes. |
Keyboard Shortcuts - Delay between shortcuts (seconds) | Delay time between consecutive special keys. |
Keyboard Shortcuts - Delay between keys (seconds) | Delay time between consecutive keystrokes. |
The settings below apply to the Check App State, Extract Table Data, Highlight, Hover, and Inject Js Script activities.
Check App State - Timeout (seconds) | How long to wait for the target element to appear or disappear. |
Extract Table Data - Delay between pages (seconds) | If the data spans multiple pages, how long to wait for each page to be loaded. |
Highlight - Duration (seconds) | How long to highlight the target element. |
Hover - Duration (seconds) | How long to hover over the target element. |
Inject Js Script - Execution world | Applies the InjectJs.ExecutionWorld setting globally. For details, see the Inject Js Script activity. |
Close Popup - Popup Appear Timeout | The amount of time (in seconds) to wait for a pop-up to appear. |
Information about the methods used to identify targets and anchors, and the performance of each method at runtime can be saved in the Robot execution logs. The options apply to all supported activities.
Property name | Property Description | Impacted Activities |
Log target & anchor search steps | Log the methods used to identify targets and anchors. |
Log targeting methods timings | Log the performance of each targeting method. |
Log audit information | Specifies at what level the logs generated by the Use Application/Browser activity are stored. The following options are available:
| Use Application/Browser |
