uipathctl 参考指南
上次更新日期 2025年4月28日
uipathctl rke2 先决条件
描述
先决条件检查命令。
uipathctl rke2 prereq [flags]uipathctl rke2 prereq [flags]
选项
      --excluded strings   components to be excluded from execution, defaults to none
  -h, --help               help for prereq
      --included strings   components to be included in the execution, defaults to all
  -o, --output output      output format. one of [json,yaml,text] (default text)
      --upgrade            include upgrade-related checks      --excluded strings   components to be excluded from execution, defaults to none
从父命令继承的选项
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • 描述
  • 选项
  • 从父命令继承的选项
此页面有帮助吗?
获取您需要的帮助
了解 RPA - 自动化课程
UiPath Community 论坛
信任与安全
© 2005-2026 UiPath。保留所有权利。
