Automation Hub 用户指南
启用存储
Automation Store 可以通过我们在 Automation CloudTM 和 Automation Hub 中提供的设置启用和控制。
作为想要设置应用商店以向企业用户推出应用商店的管理员,您需要执行以下合并步骤:
  1. Start by from Automation SuiteTM.
  2. Decide how you want your users to interact with the Automations in the Store by checking the Instant consumption settings in Automation Hub.
  3. The Store can be integrated with Orchestrator (Cloud), so check the details of the Orchestrator connection in Automation Hub.
  4. The end goal is for your users to run the Automations from the Store in their UiPath Assistant, so check the minimum requirements for the Assistant setup and how to perform the connection.
此页面有帮助吗?
连接
需要帮助? 支持(opens in new window)
保持更新
