test-suite
Test Suite User Guide
Last updated Apr 15, 2025
Analyzing a Project
Prerequisites:
  1. Run the package task, using uipcli package. You can see a list of the available sub-tasks.
  2. Specify the required parameters and run the analyze sub-task.
    See the list of parameters below.
Note:
Project validation is not performed by the Pack or Analyze tasks of UiPath CLI.
Legend: (*) - Optional, recommended when using additional package feeds.
Parameter
--analyzerTraceLevel
Choose what types of messages to output after analyzing:
  • Off = don't show any message
  • Error
    -Warning
    -Info
    -Verbose.
-stopOnRuleViolation
The job fails when any rule is violated.
--treatWarningsAsErrors
Treat warnings as errors.
--resultPath
The full path to a JSON file where you want to store the results.
If you don't add this as an argument, then the results will print only in the standard console.
--ignoredRules
A list of rules that you want to ignore during the analysis, separated by commas.
--orchestratorUsername (*)
(Required if you use Basic Authentication, through a username and a password)
The username used for authenticating to Orchestrator. You must pair it with the corresponding password.
--orchestratorPassword (*)
The password used for authenticating to Orchestrator. You must pair it with the corresponding username.
-orchestratorAuthToken (*)
(Required if you use token-based authentication)
The OAuth2 refresh token used for authenticating to Orchestrator. You must pair it with the Account Name and Client ID.
--orchestratorAccountName (*)
The Orchestrator CloudRPA account name. You must pair it with the OAuth2 refresh token and Client ID.
--orchestratorAccountForApp (*)
The Orchestrator CloudRPA account name(organization name). You must pair it with the Application ID, Application Secret, and Application scope for external application.
--orchestratorApplicationId (*)
The external Application ID. You must pair it with the **Application Account, Application Secret, and Application scope.
--orchestratorApplicationSecret (*)
The external Application Secret. You must pair it with the Application Account, Application ID, and Application scope.
--orchestratorApplicationScope (*)
The list of application scopes, separated by single spaces. You must pair it with the Application Account, Application ID, and Application Secret for external application.
--orchestratorFolder (*)
The name of the target Orchestrator folder.
To input subfolders make sure to input both the parent folder name and the name of the subfolder. For instance, use AccountingTeam\TeamJohn.
--orchestratorUrl (*)
The URL of the Orchestrator instance.
--orchestratorTenant (*)
The tenant of the Orchestrator instance where you want to delete a machine.
-l,--language
The orchestrator language.
-y, --disableTelemetry
Disable telemetry data.
--traceLevel
Display the trace of the events.
-identityUrl (Required only for PaaS deployments) The URL of your identity server.
--disableBuiltInNugetFeeds
Disable built-in nuget feeds.
--help
Displays the parameters and examples for this command.
--version
Display version information.
Project(s) Path (pos.0) (Required) The path to the project.json file, or the path to the folder that contains multiple project.json files.
Usage:
package analyze <project_path> [--analyzerTraceLevel <analyzer_trace_level>] [--stopOnRuleViolation] [--treatWarningsAsErrors] [--saveOutputToFile] [--ignoredRules <activity_1_id,activity_2_id,activity_3_id,activity_4_id>] [--orchestratorUrl <orchestrator_url> --orchestratorTenant <orchestrator_tenant>] [--orchestratorUsername <orchestrator_user> --orchestratorPassword <orchestrator_pass>] [--orchestratorAuthToken <auth_token> --orchestratorAccountName <account_name>] [--orchestratorFolder <folder>]package analyze <project_path> [--analyzerTraceLevel <analyzer_trace_level>] [--stopOnRuleViolation] [--treatWarningsAsErrors] [--saveOutputToFile] [--ignoredRules <activity_1_id,activity_2_id,activity_3_id,activity_4_id>] [--orchestratorUrl <orchestrator_url> --orchestratorTenant <orchestrator_tenant>] [--orchestratorUsername <orchestrator_user> --orchestratorPassword <orchestrator_pass>] [--orchestratorAuthToken <auth_token> --orchestratorAccountName <account_name>] [--orchestratorFolder <folder>]
Examples:
  • package analyze "C:\UiPath\Project\project.json"
  • package analyze "C:\UiPath\Project\project.json" --analyzerTraceLevel "Error"
  • package analyze "C:\UiPath\Project\project.json" --analyzerTraceLevel "Error" --stopOnRuleViolation
  • package analyze "C:\UiPath\Project\project.json" --analyzerTraceLevel "Error" --stopOnRuleViolation --treatWarningsAsErrors
  • package analyze "C:\UiPath\Project\project.json" --analyzerTraceLevel "Error" --stopOnRuleViolation --treatWarningsAsErrors --resultPath "C:\UiPath\Project\output.json"
  • package analyze "C:\UiPath\Project\project.json" --analyzerTraceLevel "Error" --stopOnRuleViolation --treatWarningsAsErrors --resultPath "C:\UiPath\Project\output.json" --ignoredRules "ST-NMG-009,ST-DBP-020,UI-USG-011,ST-DBP-020"
  • package analyze "C:\UiPath\Project\project.json" --analyzerTraceLevel "Error" --stopOnRuleViolation --treatWarningsAsErrors --resultPath "C:\UiPath\Project\output.json" --ignoredRules "ST-NMG-009,ST-DBP-020,UI-USG-011,ST-DBP-020" --orchestratorUrl "https://orchestratorurl.com" --orchestratorTenant "default" --orchestratorUsername "username" --orchestratorPassword "\_ye5zG9(x" --orchestratorAuthToken "AuthToken" --orchestratorAccountName "AccountName" --orchestratorFolder "OrchestratorFolder"
Adding an External Application
To register an external application so that it can access your UiPath resources using OAuth:
  1. Log in to the tenant as an Administrator.
  2. Go to Tenant > Manage access > Assign roles and select Manage Accounts & Groups.
    The tenant-level opens.
  3. Along the left, select External Applications.
    The External Applications page opens, listing all the existing external applications registered for the current tenant:
  4. Select Add Application.
  5. Fill in the Application Name field.
  6. Select an option for Application Type.
    If you select Confidential application, you receive an app secret at the end, so make sure your application can store it securely. If it can't, select Non-confidential application.
  7. Under Resources, select Add Scopes.
    The Edit Resource panel opens on the right, where you can select the resources to which the application should have access.
  8. From the Resource drop-down list, select the UiPath API that the application can use.
    Note: You can only add scope for one resource at a time. If you want to allow access to multiple resources, repeat this process to add scope for each resource.
  9. On the User Scope(s) tab, select the check boxes for the logical API permissions that you want to grant, as needed.
    Granting permissions under user scope means that the external application can access those resources within a user context and a user with the appropriate permissions must be logged in.
  10. If this is a confidential application, you can switch to the Application Scope(s) tab to also grant application-level permissions for the selected resource, as needed.
    With permissions under application scope, the external application has access to application-wide data for the selected scopes without the need for user interaction.
    Non-confidential applications cannot access application scope.
  11. Select Save.
    The panel closes and the selected resource and scopes are added to the Resources table in the form.
  12. If the external application can accept it, you can add a URL in the Redirect URL field and the authorization response is sent there. The application can then use it to access UiPath resources.
  13. Select Add to create the registration.
    A confirmation message opens. For confidential applications, the confirmation message includes the app secret that the registered external application can use to request authorization. Make sure you save it in a secure location because you cannot revisit it.
