- Getting started
- Understanding UiPath Robot
- UiPath Assistant
- Installation requirements
- Installing robots for unattended automations
- Configuring robots for unattended automations
- Connecting robots for unattended automations to Orchestrator
- Setting up Windows Server for high-density robots
- Redirecting robots through a proxy server
- Implementing authentication
- Adjusting registry settings for execution in minimized RDP windows
- Using network locations
- Setting up Linux robots
- Configuring package signature verification
- Setting up package folders and network paths
- Configuring activity feeds
- Deploying unattended automations
- Installing robots for attended automations
- Configuring robots for attended automations
- Integrations
- Troubleshooting
Installing using deployment templates
Deploying Service Mode Robots on AWS infrastructure allows you to run unattended automations on Amazon EC2 instances.
The following deployment options are available:
Azure marketplace deployments allow you to deploy UiPath solutions directly from the Azure portal.
Deploying through Azure Market creates a modern folder in Orchestrator. This folder comes with assigned user accounts and machine templates. The solution structure has the following naming:
- Folder:
AzureDeployed
User account (one for each deployed robot):
Azure-<VM Name>-<RandomString>
Robot account (for each user):
<VM Name>\<Machine Admin Username>
- Machine template (one for each deployed robot):
AzureTemplate-<VMName>
The Azure Portal wizard allows you to deploy one or more Robots. It uses a Windows Virtual Machine, which runs scripts to configure the Robot and connect it to Orchestrator. The machine, together with a Network Interface Card and a separate storage account, is deployed within a virtual network.
To deploy robots using the Azure Portal wizard:
