robot
2026.10
Guia do admin do Robô
Componentes do Robô
Robot Service, Unified Runtime with its executors, and Command Line Interface: the core components that make up UiPath Robot.
A UiPath Robot is built on the following components:
  • Serviço de Robôs da UiPath — esse serviço é vital para manter a conexão entre o Robô e o Orchestrator, pois envia sinais de "pulsação" em intervalos regulares para informar o Orchestrator sobre o status do Robô. Essa comunicação ajuda a monitorar o desempenho do Robô e gerenciar a orquestração.
  • Unified Runtime—The Robot's runtime for every workload. It hands each job to the executor that workload needs:
    • The .NET executor, or Robot Executor, runs RPA processes and test cases. It performs activities within a workflow, such as clicking buttons, typing in fields, or extracting data – essentially replicating the actions a human takes on a computer.
    • Executor packages run agents, functions, and API workflows, in a host process that the Robot Service starts.
  • A interface de linha de comando — a interface de linha de comando (CLI) do UiPath Robô permite que você controle e gerencie a execução de fluxos de trabalho de automação diretamente da linha de comando, fornecendo outro método de interação além do UiPath Assistant.
The Update Service, a component of earlier Robot versions, doesn't ship in 2026.10. The UiPath Platform Installer installs and updates the Robot. For details, refer to Updating the Robot.
