orchestrator
Orchestrator user guide
Optimizing Unattended Infrastructure Using Machine Templates
How machine templates optimize unattended infrastructure in Orchestrator for background and foreground automation.
Note:
The following table shows the UiPath® Robot version required to execute processes according to their target frameworks and OS compatibility considerations.
Operating system (target framework)Robot version
Windows - Legacy (.NET Framework 4.6.1)Any
Windows (.NET 5.0+)2021.10+
Cross-platform (.NET 5.0+)2021.10+
The following table shows the UiPath Robot version required to run foreground/background processes according to the robot credential considerations.
Process typeRobot credential considerationsRobot version
BackgroundWith credentialsAny
ForegroundWith credentialsAny
BackgroundWithout credentials2021.10+
ForegroundWithout credentialsInvalid configuration. You need credentials to run foreground jobs.
Optimizing Unattended Infrastructure​
Your unattended workload has unique infrastructure needs that can change over time. You can maximize efficiency and minimize waste by restricting the machine template and the associated machine infrastructure to executing a particular type of process.
  1. Add or edit a new machine template on the Machines page.
  2. Configure the two options available in the Supported usage section according to your needs:
    Figure 1. Supported usage section
    Process type
    On the machine infrastructure employing that machine template you can execute:
    • Foreground only - only foreground processes, (1)
    • Background only - only background processes, (2)
    • All - both background and foreground processes. (3)
    Process compatibility
    • Windows only - Windows-compatible processes only, (4)
    • Cross-platform only - cross-platform processes only, (5)
    • All - both Windows-compatible and cross-platform processes. (6)
Example​
Let's say you've been using UiPath Studio for quite some time now, so inevitably you have gotten yourself a quite diverse collection of automations: background and foreground processes, some developed using.NET Framework 4.6.1, newer ones developed on.NET 5.0.
Your infrastructure consists of:
  • one Windows desktop
  • one high-density Windows Server
  • three Linux machines
How would an efficient optimization strategy look like?
No of processes
Compatibility (set in Studio)
Machine Template Settings (set in Orchestrator)
Why
4 background processes
Windows - Legacy
We connect one Windows desktop using template A which we define as follows:
Process type = Background onlyProcess compatibility = Windows onlyUnattended Runtimes = 4
  • .NET Framework 4.6.1 processes can only run on Windows machines.
  • Background processes can run concurrently under the same account.
  • Template A has 4 runtimes assigned, allowing execution of 4 jobs concurrently.
6 background processes
Cross-platform
(.NET 5.0 or higher)
We connect 3 Linux machines using template B which we define as follows:
Process type = Background onlyProcess compatibility = Cross-platform onlyUnattended Runtimes = 2
  • .NET Framework 5.0 processes can run on any type of machine.
  • Template B only allows execution of background processes on the connected Linux machines.
  • Template B has 2 runtimes assigned, allowing execution of 2 jobs concurrently on each connected Linux machine: 2 jobs x 3 machines results in an execution capacity of 6 concurrent jobs.
10 foreground processes
Windows
We connect the Windows server using template C which we define as follows:
Process type = Foreground onlyProcess compatibility = Windows onlyUnattended Runtimes = 10
  • .NET Framework 5.0 processes can run on any type of machine, Linux machines included, but because these are foreground processes developed for Windows, you need to run them on Windows machines.
  • One account can run one foreground process at a time.
  • A HD Windows Server allows opening multiple account sessions.
  • Template C has 10 runtimes assigned, meaning 10 sessions are opened simultaneously, allowing execution of 10 foreground jobs concurrently.
Tips & Tricks​
  • Allocate background processes execution to cheaper machines (such as Linux).
  • Set Windows machines aside for foreground automation.
  • Background processes developed using .NET Framework 4.6.1 require Windows. You can resort to Windows desktops for concurrent execution. You do not need a Windows server for background processes, nor a high-density environment, since background jobs can run concurrently under the same account.
  • You need 2021.10+ robots to execute .NET. 5.0 or higher processes
Job Allocation​
Orchestrator does not allow starting jobs on invalid configurations. Trying to start a job in an invalid setup results in a descriptive error message providing you with details about how to fix your configuration.
Starting a job using dynamic allocation, i.e. no machine or account specified, with an incompatible folder setup, results in an error. If you do not correct the setup, jobs stay pending indefinitely. For example, trying to run a.NET Framework 4.6.1 background job when there are only cross-platform templates in the folder does not work, as jobs stay pending until the configuration is fixed.
For details about how to fix the configuration, in the folder context, navigate to Automations and select the Jobs tab, then select the relevant job in the grid. The Job Details side panel opens, displaying information on how to fix the configuration.
Invalid Configurations​
  • Foreground processes are developed on top of a UI and need a UI to get executed. Currently, UiPath foreground automation is only possible on Windows. For this reason, foreground automation on cross-platform-only machines is not a valid setup.
  • Employing a Windows only template on a Linux machine is not a valid setup. Use Cross-platform only templates or unrestricted templates (All).
  • Employing a Cross-platform only template on a machine with a UiPath Robot version smaller than 21.8+ is not a valid setup. Update the version or set the machine template to Windows only or All.
  • Optimizing Unattended Infrastructure​
  • Example​
  • Tips & Tricks​
  • Job Allocation​
  • Invalid Configurations​
Connect
Stay updated
