document-understanding
- Démarrage
- Keyword Based Classifier
- FlexiCapture Classifier
- Machine Learning Classifier
- Regex Based Extractor
- Form Extractor
- FlexiCapture Extractor
- Paquets ML
- Pipelines
- Data Manager
- Services OCR
- Apprentissage profond
- Licences
- Référence (Reference)
- UiPath.Abbyy.Activities
- UiPath.OCR.Activities
- UiPath.OCR.Contracts
- UiPath.OmniPage.Activities
- UiPath.PDF.Activities
Configuration OCR
Le tableau ci-dessous fournit des détails sur la configuration OCR lorsque vous créez ces paquets ML dans AI Center.
| Paquet ML | Détails (Details) |
| UiPath Document OCR | Aucun
Veuillez laisser la configuration OCR vide lors de la création de ce package. |
| Document Understanding | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| Classifieur de documents | Aucun
| Factures | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| Factures, Australie | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| Factures, Inde | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| Factures, Japon | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. Only Google Cloud Vision OCR is currently supported. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| InvoicesChina | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. Only Google Cloud Vision OCR is currently supported. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| Reçus | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. |
| Bons de commande | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| Cartes d’identité | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| Passeports | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| RemittanceAdvices | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| DeliveryNotes | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| W2 | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| W9 | Facultatif. This OCR configuration is used when you check the UseServerSideOCR checkbox on the Machine Learning Extractor activity. This is also necessary for using the eval.redo_ocr environment variable in Evaluation Pipelines. |
| Form Extractor | Aucun
Veuillez laisser la configuration OCR vide lors de la création du package. |
| Extracteur de formulaires intelligents | Requis. Veuillez remplir l'URL de la compétence ML HandwritingRecognition que vous devez déployer avant de créer ce paquet. |
| Classifieur de mots clés intelligents | Aucun
| HandwritingRecognition | Aucun
