document-understanding
Document Understanding User Guide
Last updated Dec 4, 2025
Install and use
This page describes how to deploy and configure Document UnderstandingTM, as well as special instructions on how to use Document UnderstandingTM on Automation Suite.
Dependencies
Document Understanding has a dependency on AI Center, meaning that AI Center always needs to be installed if Document Understanding is installed.
Also, Orchestrator must be activated before using Document Understanding.
Hardware requirements
Before starting the Document Understanding installation, make sure to check and satisfy all requirements for Automation Suite for single-node and for multi-node here.
A GPU is strongly recommended for Document Understanding in one of the following scenarios:
  • If you retrain the Document Understanding models (DocumentUnderstanding - the general model, Invoices, Receipts, etc.) on AI Center.
    Training on CPU is 5-7 times slower and model performance degrades compared to training on GPU.
  • If you run UiPathDocumentOCR (non-edge version) on AI Center to process more than 2 million pages a year.
    If you do not use a GPU, slow performance may impact the product experience.
    For more details about how to provision a GPU, see Adding a dedicated agent node with GPU support.
SQL Server requirements
Document Understanding requires the FullTextSearch feature to be enabled on the SQL server. Otherwise, the installation fails without an explicit error message.
Resources
Configuration file
Check the Document Understanding configuration file here.
Access to the models
Access Form Extractor and Intelligent Keyword Classifier, with the below public URL:
  • <FQDN>/du_/svc/formextractor
  • <FQDN>/du_/svc/intelligentkeywords
Note: When using a public URL, replace the <FQDN> placeholder with the actual environment information.For example <FQDN>/du_/svc/formextractor becomes https://servicefabricserver.domain.com/du_/svc/formextractor when used in a workflow.
Enable or disable Document Understanding
As a post-installation operation, you can enable or disable Document Understanding. More details can be found here.
Enable or disable OCR for Chinese, Japanese, Korean
If you want to use the OCR for Chinese, Japanese, Korean endpoint in an offline environment, you need to install the offline bundle by following these instructions, and once the bundle is installed, you have to enable the OCR in ArgoCD.
To enable or disable the Chinese, Japanese, Korean OCR, check the instructions from the Automation Suite Admin Guide.
Enable or disable UiPath Extended Languages OCR
To enable or disable the Extended Languages OCR, check the instructions from the Automation Suite Admin Guide.
Troubleshooting
Check the Document Understanding-related issues here.
