Process Mining
Last updated Dec 19, 2025
Basic troubleshooting guide
Introduction
The purpose of this Troubleshooting page is to serve as a knowledge base for common problems faced or questions asked when using Process Mining. It does not provide a complete list of all problems you may encounter, but is intended to provide guidance with the most common issues. If you encounter any issues that are not covered here, feel free to reach out to UiPath® Technical Support.
How to cancel a data run from the database
This section describes how to manually stop the data run from the database in case of a failing data run.
Follow these steps.
  1. Retrieve the App ID of the process app for which you want to cancel the data run. Check outProcess App properties.
  2. Contact you database administrator to run the following SQL query in the AutomationSuite_ProcessMining_Metadata database:
    with Ingestion_tbl as (select top 1 * from dbo.Ingestions where AppId = '<app ID>' and [Status] = 1 order by LastUpdated desc) update Ingestion_tbl set [Status]=3 where <app ID> should be replaced with the App ID retrieved in Step 1.
    The following illustration shows an example.
    Example query to cancel a data run
  3. Refresh Process Mining Portal page.
  4. Upload data for the process app.
How to add an IP table rule to use SQL Server port 1433
Only the default SQL Server port 1433 can be used for the Airflow metadata SQL server database AutomationSuite_ProcessMining_Metadata. If your organization policies or firewall rules do not allow using port 1433, you can redirect incoming traffic directed at port 1433 of the SQL Server IP address to a new SQL Server IP and port.
Use the following Linux command to add a nat rule in the IP tables PREROUTING chain:
iptables -t nat -A PREROUTING -d <sql server IP> -dport 1433 -j DNAT --to-destination <sql server ip>:<sql server port>iptables -t nat -A PREROUTING -d <sql server IP> -dport 1433 -j DNAT --to-destination <sql server ip>:<sql server port>
Replace <sql server IP> and <sql server port> with your respective SQL Server IP address and port number.
Note:
This command should be run as a root user or a sudo user.
To make the connectivity available from node level as well, an additional rule in the output chain is required:
iptables -t nat -A OUTPUT -p tcp -d <sql server IP> --dport 1433 -j DNAT --to-destination <sql server ip>:<sql server port>iptables -t nat -A OUTPUT -p tcp -d <sql server IP> --dport 1433 -j DNAT --to-destination <sql server ip>:<sql server port>
The iptables commands needs to be executed on all the nodes of the cluster.
To make the IP table rules persistent, run the following command:
iptables-save > /etc/sysconfig/iptables
systemctl enable iptablesiptables-save > /etc/sysconfig/iptables
When creating a process app the status stays in Creating app
Possible cause
The database service is not set correctly during installation or upgrade.
Solution
Make sure to configure the process app security. Check out Configuring process app security.
Note:
If you cannot update the SQL server permission, it is recommended to change the app_security_mode from system_managed to single_account.
