- Getting started
- Host administration
- Organizations
- Authentication and security
- Licensing
- Tenants and services
- Accounts and roles
- About accounts and groups
- Managing accounts and groups
- Managing access
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
The following pages describe how you can manage access in Automation Cloud:
Roles are a collection of permissions and represent a more granular layer for managing user access, following the broader option of maintaining access through groups. You can add roles to either groups so that all member accounts inherit them, or to individual accounts.
Roles can include several permissions at either the organization level, or at the service level, so there are:
- organization-level roles: these roles control the permissions that accounts have on organization-wide options. They are available in the Automation Suite portal by default and you cannot change them, nor can you add new ones.
- service-level roles: these roles control the access rights and actions that accounts can perform in each UiPath® service you own. They are managed from within each service and can include default roles which you cannot change, as well as custom roles that you create and manage in the service.
Accounts and groups typically have an organization-level role and one or more service-level roles.
Groups and roles
In the following table you can view the roles that are assigned to accounts when they are added to a group. For example, adding an account to the Administrators default group grants them the Organization Administrator role for the organization and the Administrator role within your services. This user can manage both organization-level roles from Admin, then select Accounts and Groups, as well as service-level roles.
Group membership |
Organization-level role |
Service-level roles for Orchestrator |
Administrators |
Organization Administrator | |
Automation Users |
User |
Automation User at folder level 1 Allow to be Automation User at tenant level |
Automation Developers |
User |
Automation User at folder level 1 Folder Administrator at folder level 1 Allow to be Automation User at tenant level Allow to be Folder Administrator at tenant level |
Everyone |
User |
No roles. |
Automation Express |
User |
[Custom group] |
User |
No roles by default, but you can add roles to the group as needed. |
1 The roles are assigned to the Shared modern folder, if it exists.
Organization-level roles
Accounts can have only one organization-level role. This role controls the access that the account has to options within the portal area, such as the tabs they can view on the Admin page or the options available to them on the Home and Admin pages.
At organization level, the roles Organization Administrator and User are available.
You cannot change these roles or add new roles at the organization level.
Service-level roles
Service-level roles control access rights and permitted actions within each of your UiPath services, such as the Orchestrator service, or Data Service. The permissions for each service are managed within the service itself, not from the organization Admin page.
To grant permissions for a service to accounts, you can do the following:
- Assign service-level roles to a group to grant those roles to all member accounts - you do this in the service.
- Add accounts to a group that already has the required service-level roles - you do this from Admin > Accounts and Groups.
- Assign roles to an account - you do this in the service.
You can manage and assign service-level roles from within each service and you need the appropriate permissions in the service.
For example, users with the Administrator role in Orchestrator can create and edit roles, and assign roles to existing accounts.
There are two ways to assign roles to an account:
- Direct provisioning implies manually assigning roles to an existing account. You can do this by adding the account to a group, by assigning service-level roles to the account directly, or a combination of both.
- Auto-provisioning is only applicable if your UiPath organization is integrated with a third-party identity provider (IdP), such as Microsoft Entra ID). In this case, to fully hand off identity and access management to the external provider, you can set up the UiPath platform so that any directory account can receive the appropriate roles without the need for any actions in the UiPath platform. The IdP administrator then has control over a user's access and rights in the UiPath organization by creating and configuring the account in the external provider alone.
Direct provisioning
Assigning organization-level roles
Organization-level roles are predefined and cannot be changed.
Organization administrators can assign organization-level roles to individual accounts from Admin > Accounts and Groups by adding accounts to a default or custom group.
If you have linked your UiPath organization to a directory, such as Microsoft Entra ID, then it is possible to also assign organization-level roles to directory groups by adding them to groups, same as with accounts. This is not possible with local groups.
Managing service-level roles
You manage and assign service-level roles from within the services. You can assign roles to groups (recommended), or to accounts that have already been added.
For information and instructions, see the applicable documentation:
Service |
Details |
Orchestrator |
Managed from Orchestrator. Learn more about roles in the Orchestrator guide. |
Actions |
Processes |
Automation Hub |
Managed from Automation Hub. For more information about which roles are required and instructions for assigning them, see Role description and matrix . |
Automation Store |
AI Center |
Managed from Orchestrator. For information about the roles required to use AI Center, see AI Center access control. |
Data Service |
Managed from Data Service.
| Document Understanding™ |
Managed from Document Understanding. For more information about which roles are required and instructions for assigning them, see Role-based access control . |
Task Mining |
Managed using Automation Cloud organization-level roles. For information about the rights that organization-level roles grant in Task Mining, see Managing access and roles in the Task Mining documentation. |
Test Manager |
Managed from Test Manager. For information and instructions, see User and group access management . |
Assigning roles to an account
If you want to granularly control the access a certain account has in a service, but you don't want to add new roles to an entire group, you can explicitly add the account to the service and assign one or more service-level roles to it directly. For example, you can add an account to the Orchestrator service .
For information about the available roles and instructions, see the documentation for the target service, as previously described.
Auto-provisioning
Through auto-provisioning, any directory account can be set up with access and rights for using the UiPath platform directly from the external identity provider (IdP).
Auto-provisioning requires a one-time setup after you enable an integration with a third-party IdP: Microsoft Entra ID or other IdPs that are connected used SAML integration.
