- Getting started
- Host administration
- Organizations
- Authentication and security
- Allowing or restricting basic authentication
- Setting up the Microsoft Entra ID integration
- Restricting access to a set of users
- Session policy
- Setting up encryption key per tenant
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
Tenants and services in an organizations are, by default, available to all directory users and groups who authenticate successfully.
Organization administrators can configure an organization access control policy to either allow access to all users in a directory or to restrict access to a specified list of allowed members. For any access attempt, the system checks if they are on the list of allowed entities. If they are not on the list, they are denied access and an error is raised.
Upon enabling the organization access policy, it may take up to one hour for the policy to take effect. Once in effect, users who are restricted by the policy will be denied access to all user-facing services, and services that are accessible using user tokens.
Configuring the organization access policy
To change your access policy, follow these steps:
Log in as an organization administrator.
Navigate to the Administration page, make sure that the organization is selected at the top of the left pane, and then select Security.
On the Access Restriction tab, select the access policy for your organization.
- Everyone (Default): This option allows all users and groups from your directory to sign in and access tenants and services. This option is recommended if you want to allow all users in the directory to access the organization without any additional restrictions.
- Only allowed members: This option restricts access to a specific list of users and groups. Only users and groups on the allowed list will be able to sign in and access the organization, while all other users are denied access.
If you selected the Only allowed members policy, you also need to define the list of allowed members.
Note:It may take up to one hour for the policy to take effect. Once in effect, users who are restricted by the policy will be denied access to all user-facing services, and services that are accessible using user tokens.
Adding users to allowlist
The users and groups included in the allowlist are only considered when the Only allowed members policy is enabled.
To configure the list of members that are allowed access to the organization, follow these steps:
On the Access Restriction tab, select Only allowed members. This policy restricts access to the platform to only the allowed entities. Without enabling this policy, the allowed list will have no impact on access control restrictions.
In the Allowed list members table, select Add member. The Add allowed members window is displayed.
In the Add names field**,** enter the names or emails of the entities that are allowed access to the organization.
Once done, select Add. Once the access control policy has been configured, only the users and groups on the allowed list will be able to access the platform. Any other user who attempts to log in will be denied access.
Removing users from the allowlist
To remove a members from the allowlist, follow these steps:
In the Allowed list members table, locate the member you want to remove and select the corresponding Remove member icon.
Note:The Administrators group cannot be removed.
To remove multiple members, select the corresponding checkboxes and select Remove at the top of the table. Once the policy takes effect, the removed member is denied access to the organization.
