2022.4
Automation Suite API guide
  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Allocate Licenses to a Group
As an organization admin, use this endpoint to allocate licenses to a group. To do that, you need to create an external application, with the scope PM.License.Write.
API Endpoint​
PUT https://{yourDomain}/{organizationName}/lease_/api/account/{accountId}/user-license/group/{groupId}
Request Headers​
Note:
To obtain the {access_token}, make sure to authenticate through the ROPC method described here.
Path Parameters​
Path paramData typeDescription
accountId
(required)
StringThe ID of the organization in which your tenant resides.
groupId
(required)
StringThe ID of the group you want to allocate licenses to.
You can retrieve this ID by following these steps.
Request Body​
The request body contains the array of license codes for various products and their corresponding quantity.
    "userBundleCodes": ["string"]
Note:
  • To see the available user bundle codes you may use in the request body, check out the user license codes.
  • You may allocate as many licenses as the organization has purchased.
Responses​
200 OK​
Returns the allocated group licenses.
No account license is allocated for the indicated organization.
Example Request​
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}.
  • Your {access_token} is: 1234 (for length considerations).
  • The {accountId} of the tenant that needs license allocation is: song-one
  • The {groupId} is: group-01.
  • You want to allocate user licenses to the group as follows:
The call should resemble the following example (cURL):
curl --location --request POST 'https://https://{yourDomain}/{organizationName}/lease_/api/account/1234/user-license/group/group-01' \
--header 'Content-Type: application/json' \
--data-raw '{
    "userBundleCodes": ["RPADEVPRONU", "IDU", "CTZDEVCU"],
    "useExternalLicense": false
--data-raw '{
Here's the response body for a successful license allocation:
  "groupId": "string",
  "organizationId": "string",
  "useExternalLicense": false,
    "string"
    "string"
  • API Endpoint​
  • Request Headers​
  • Path Parameters​
  • Request Body​
  • Responses​
  • 200 OK​
  • 404​
  • Example Request​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
