- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated Sep 20, 2024
Get the current Token Signing certificate observed in the cluster in
pem
format.
The command defaults to the current context in the
kubeconfig
file. If the --kubeconfig
flag is set, it uses the kubeconfig
file specified by the flag.
uipathctl config token-signing-certificates get [flags]
# Get the current token signing certificate from the cluster
# Get the current token signing certificate from the cluster with additional certificate information
uipathctl config token-signing-certificates get --show-details
# Get the current token signing certificate from the cluster identified by the current context in the kubeconfig file
uipathctl config token-signing-certificates get --kubeconfig cluster.kubeconfig
-h, --help help for get
--show-details if true, additional token certificate information will be printed
