Automation Suite
- Overview
- Requirements
- Proxy
- SQL database
- Caching
- Storage
- Configuring NGINX ingress controller
- Certificate requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated May 20, 2024
In standard configuration, Automation Suite provisions a Load Balancer Kubernetes service type configured with Istio Gateway as an ingress controller for the requests coming from the network load balancer.
If you already have an NGINX ingress controller in your cluster and want to continue to use it, you must configure the Kubernetes
service_type
as cluster_IP
instead of Load Balancer. This document provides the necessary changes required for that configuration.
Important:
To manage large headers, adjust the
proxy-buffer-size
in the ingress annotation as follows:
nginx.ingress.kubernetes.io/proxy-buffer-size: "8k"
You must update your NGINX specification with
istio-ingressgateway
as a backend service and specify the port number 80. Additionally, if you have your own Network Policies,make sure they are
configured correctly to allow NGINX and Istio routing.
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
namespace: istio-system
spec:
ingressClassName: nginx
tls:
- hosts:
- "<FQDN>"
- "*.<FQDN>"
secretName: nginx-tls
rules:
- host: "<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 80
- host: "*.<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 80
kind: Ingress
metadata:
spec:
tls:
- hosts:
- "<FQDN>"
- "*.<FQDN>"
rules:
- host: "<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 80
- host: "*.<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 80
as a backend service and specify https
as the port name.
kind: Ingress
metadata:
annotations:
nginx.ingress.kubernetes.io/backend-protocol: "https"
nginx.ingress.kubernetes.io/proxy-ssl-name: "<FQDN>"
nginx.ingress.kubernetes.io/proxy-ssl-server-name: "on"
nginx.ingress.kubernetes.io/proxy-ssl-secret: "istio-system/istio-ingressgateway-certs"
nginx.ingress.kubernetes.io/proxy-ssl-verify: "on"
spec:
tls:
- hosts:
- "<FQDN>"
- "*.<FQDN>"
rules:
- host: "<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
- host: "*.<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
kind: Ingress
metadata:
annotations:
spec:
tls:
- hosts:
- "<FQDN>"
- "*.<FQDN>"
rules:
- host: "<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
- host: "*.<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
