- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Prerequisite checks
input.json
before starting the Automation Suite installation.
uipathctl prereq
command. By default, this command verifies all the prerequisites. If you want to exclude components from the execution, use
the --excluded
flag.
uipath-check
namespace. You must either allow the creation of the uipath-check
namespace or create it yourself before running the checks/tests. In addition to this, some checks/tests require that you
allow the communication between the uipath-check
and uipath
namespaces, or that you enable the use of hostNetwork
The checks in the following table are run on each node:
Check |
Description |
SQL Connection |
Validates that Automation Suite can successfully connect to SQL server for UiPath® products and shared services (such as Identity,
Portal, Org Mamagement, etc.) using the SQL connection strings provided in
input.json . This is mandatory for a successful installation.
SQL DB roles |
Validates the necessary roles and permissions required by UiPath® products. This is mandatory for a successful installation. |
SQL DB compatibility |
Validates SQL DB compatibility requirements. |
FQDN resolution |
Validates that the FQDN and the sub-domains are successfully resolvable. |
Object Storage API |
Validates that Object store APIs are accessible based on access information provided in
input.json . This is mandatory for a successful installation of UiPath® Services.
Cache / Redis |
Validates the connection to Cloud Redis or ElastiCache. This is mandatory for a successful installation. |
Capacity |
Validates you have minimum worker nodes' CPU and RAM capacity based on products enabled in
input.json .
Storage Class |
Validates the storage classes for File Storage are configured as required for Automation Suite Robots. |
Optional Components |
Validates that your cluster has components that you chose to exclude from the Automation Suite installation. |
Ingress |
Validates that the cluster ingress is configured correctly and the FQDN URL requests can reach UiPath® products. |
Network Policies |
Checks if network policies configured in Automation Suite are compatible with the cluster. |
Registry |
Validates that Automation Suite can access the UiPath® docker registry. This is mandatory for a successful installation. |
Cluster Connectivity |
Validates whether the cluster communication is configured properly:
