Automation Suite
- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated Jun 3, 2024
Rotate exchanges the current Token Signing certificate data with the future one.
The command defaults to the current context in the
kubeconfig
file. If the --kubeconfig
flag is set, it uses the kubeconfig
file specified by the flag.
uipathctl config token-signing-certificates rotate [flags]
# Rotate the token signing certificates from the cluster
# Rotate the token signing certificates from the cluster identified by the current context in the kubeconfig file
uipathctl config token-signing-certificates rotate --kubeconfig cluster.kubeconfig
