Last updated Jul 9, 2025
Configuring encryption key per tenant
To configure the encryption key per tenant, take the following steps:
  1. Update the Orchestrator parameters. In the configuration file, under orchestrator, add the encryption_key_per_tenant section. For more details, see Configuring Orchestrator parameters.
    "orchestrator": {
      "enabled": true,
      "encryption_key_per_tenant": {
          "certificate_base_64": "",
          "certificate_password": "",
          "client_id": "",
          "directory_id": "",
          "vault_address": ""
    }"orchestrator": {
      "enabled": true,
          "client_id": "",
          "directory_id": "",
          "vault_address": ""
    You must convert the certificate to base64 before using it as a parameter override. To do that, run the following command:
    • PowerShell
      [convert]::ToBase64String((Get-Content -path "path_to_certificate" -Encoding byte))[convert]::ToBase64String((Get-Content -path "path_to_certificate" -Encoding byte))
    • Shell
      base64 [_path_to_certificate_]base64 [_path_to_certificate_]
  2. Apply the new configuration, and then wait for the Orchestrator ArgoCD app to synchronize.
  3. Enable the EncryptionKeyPerTenant feature by setting the following keys in appSettings:
    "EncryptionKeyPerTenant.Enabled": "true", "EncryptionKeyPerTenant.KeyProvider": "AzureKeyVault","EncryptionKeyPerTenant.Enabled": "true", "EncryptionKeyPerTenant.KeyProvider": "AzureKeyVault",
    For more on updating appSettings, see Configuring appSettings.
    Note: SMTP settings in Identity Server are not encrypted with the per-tenant key. After enabling encryption key per tenant, make sure to re-enter the SMTP password in the Automation Suite portal.
