Process Mining user guide
Last updated May 5, 2026
Loading data using Theobald Xtract Universal
This page describes how to use Theobald Xtract Universal (XU) to load data from your SAP source system into a process app. Refer to the official Theobald Software website for more information on Theobald Xtract Universal (XU).
Theobald Xtract Universal provides fast data access and extractions to SAP ECC and SAP HANA data sources. For general instructions on how to use Theobald Xtract Universal, check out the official Theobald Software website Getting Started with Theobald Xtract Universal.
Prerequisites
It is assumed that you have:
  • a valid Theobald Xtract Universal license.
    Note:
    The license is provided via UiPath® for the purpose of Process Mining.
  • set up SQL Server access with the correct permissions. Check out Setting up a SQL Server account for data upload using an extractor.
    Note:
    Loading data using Theobald Xtract Universal requires that the command line tool (xu.exe) can be executed without additional authentication.
Steps
Setting up data load using Theobald Xtract Universal requires several steps to be performed.
  1. Set up Theobald Xtract Universal
  2. Import the template extractions
  3. Configure the source
  4. Configure the destination
  5. Configure the extraction script
  6. Run the extraction script
  • Prerequisites
  • Steps
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
