Process Mining user guide
Access to Automation Suite
Access requirements for the Process Mining service on Automation Suite, including account setup and permissions needed to manage and configure process apps.
To start using the Process Mining service you need an Automation Suite account. Check out About accounts for more details.
Tenants and services​
The Process Mining service that allows you to manage and set up process apps must be enabled on each of the tenants where the Process Mining service will be used.
Note:
Process Mining is a tenant-level service signifying that each tenant's data is segregated. This means that you need to enable the service for each of the tenants where this is needed.
Changing localization settings​
The default language is English. The language can either be changed globally, with the change being propagated to all the users accessing your organization, or at a local level, for yourself only.
Note:
Process Mining App templates are not localized.
Check out Changing localization settings for more information.
  • Tenants and services​
  • Changing localization settings​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
