orchestrator
Non pris en charge par l'assistance
Guide de l'API Orchestrator
Dernière mise à jour 16 déc. 2025
Requêtes relatives aux paquets (Packages Requests)
Récupération de toutes les versions disponibles pour un paquet spécifique
Obtenir
https://{yourDomain}/odata/Processes/UiPath.Server.Configuration.OData.GetProcessVersions(processId='QueueItemsProcessing')
En-têtes de requête.
Clé (Key)
Valeur (Value)
Autorisation
Porteur
Codes de réponse
200 OK
Corps de la réponse
  "@odata.context": "https://{yourDomain}/odata/$metadata#Processes",
  "@odata.count": 2,
 "value": [
            "IsActive": true,
            "SupportsMultipleEntryPoints": false,
            "MainEntryPointPath": null,
            "RequiresUserInteraction": true,
            "TargetFramework": "Legacy",
            "Title": null,
            "Version": "1.0.6981.35861",
            "Key": "QueueItemsProcessing:1.0.6981.35861",
            "Description": "Process items from an Orchestrator queue.",
            "Published": "2021-07-23T16:40:07.793Z",
            "IsLatestVersion": false,
            "OldVersion": null,
            "ReleaseNotes": null,
            "Authors": "petrina.calota",
            "ProjectType": "Undefined",
            "Tags": null,
            "Id": "QueueItemsProcessing",
            "Arguments": {
                "Input": "[{\"name\":\"argument1\",\"type\":\"System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\"required\":false,\"hasDefault\":true},{\"name\":\"argument2\",\"type\":\"System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\"required\":false,\"hasDefault\":false},{\"name\":\"argument3\",\"type\":\"System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\"required\":false,\"hasDefault\":true}]",
                "Output": null
  "@odata.count": 2,
 "value": [
            "IsActive": true,
            "Title": null,
            "OldVersion": null,
            "Tags": null,
            "Arguments": {
                "Output": null
Téléchargement d'une version de paquet spécifique
La requête ci-dessous vous permet de télécharger le package portant le nom « add_queue_items » et la version 1.0.6654.27080.
Obtenir
https://{yourDomain}/odata/Processes/UiPath.Server.Configuration.OData.DownloadPackage(key='add_queue_items:1.0.6654.27080')
Clé (Key)
Valeur (Value)
Autorisation
Porteur
Codes de réponse
200 OK
Récupération des arguments d'un paquet
La requête GET suivante effectuée vers le point de terminaison /odata/Processes/UiPath.Server.Configuration.OData.GetArguments(key='key') renvoie tous les arguments d'entrée et de sortie d'un paquet spécifique, leur type et s'ils ont une valeur par défaut. Les arguments d'entrée; de sortie ou d'entrée/de sortie d'un projet deviennent les paramètres d'entrée et de sortie dans Orchestrator.
Obtenir
https://{yourDomain}/odata/Processes/UiPath.Server.Configuration.OData.GetArguments(key='input_output_test%3A1.3.5')
Clé (Key)
Valeur (Value)
Autorisation
Porteur
Codes de réponse
200 OK
Corps de la réponse
    "@odata.context": "https://{yourDomain}/odata/$metadata#UiPath.Core.Arguments.ArgumentMetadata",
    "Input": "[\r\n  {\r\n    \"name\": \"age\",\r\n    \"type\": \"System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": false\r\n  },\r\n  {\r\n    \"name\": \"Array\",\r\n    \"type\": \"System.Int32[], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": true\r\n  },\r\n  {\r\n    \"name\": \"trueOrFalse\",\r\n    \"type\": \"System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": true\r\n  },\r\n  {\r\n    \"name\": \"dateNow\",\r\n    \"type\": \"System.DateTime, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": true\r\n  },\r\n  {\r\n    \"name\": \"stringNew\",\r\n    \"type\": \"System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": false\r\n  },\r\n  {\r\n    \"name\": \"arrayStrings\",\r\n    \"type\": \"System.String[], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": false\r\n  },\r\n  {\r\n    \"name\": \"inOutTry\",\r\n    \"type\": \"System.Object, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": false\r\n  }\r\n]",
    "Output": "[\r\n  {\r\n    \"name\": \"output\",\r\n    \"type\": \"System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\"\r\n  },\r\n  {\r\n    \"name\": \"inOutTry\",\r\n    \"type\": \"System.Object, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\"\r\n  }\r\n]"
Modifier des paramètres au niveau du package
Il est possible de mettre à jour les paramètres d'entrée et de sortie d'un projet en effectuant une requête POST au point de terminaison /odata/Processes/UiPath.Server.Configuration.OData.SetArguments.
Remarque :
Cet appel remplace tous les paramètres précédents et offre la validation.
En outre, notez que ce point de terminaison permet de modifier les paramètres d'entrée et de sortie d'un paquet d'automatisation uniquement si vous ne l'avez pas téléchargé dans Orchestrator via l'API, la page Paquets (Packages) ou le flux NuGet.
Si vous souhaitez mettre à jour les valeurs des paramètres d’entrée uniquement, cela est possible au niveau des processus, au niveau des tâches et/ou au niveau des planifications .
Publier
https://{yourDomain}/odata/Processes/UiPath.Server.Configuration.OData.SetArguments
Clé (Key)
Valeur (Value)
Autorisation
Porteur
Corps de la requête
  "key": "input_output_test:1.3.6",
  "arguments": {
    "Input": "[{\"name\":\"arg1\", \"type\": \"System.String\", \"required\": false}]",
    "Output": "[{\"name\":\"outputArg\", \"type\":\"System.String\", \"required\":false}]"
  "arguments": {
Codes de réponse
200 OK
Récupérer des packages
Obtenir
Clé (Key)
Valeur (Value)
Autorisation
Porteur
Codes de réponse
200 OK
Corps de la réponse
  "@odata.count": 2,
    "value": [
            "IsActive": false,
            "Title": null,
            "Published": "2021-07-23T16:40:07.7933333Z",
            "OldVersion": null,
            "Tags": null,
            "Arguments": {
                "Output": null
  "@odata.count": 2,
    "value": [
            "IsActive": false,
            "Title": null,
            "OldVersion": null,
            "Tags": null,
            "Arguments": {
                "Output": null
Forum de la communauté UiPath
Confiance et sécurité
