2022.4
Guide de l'API Automation Hub
Passer des appels API Automation Hub
  • Define the token as a bearer -H 'Authorization: Bearer [Tenant ID]/ [Token_generted_from_the_Open API_page].
  • If an App Key was defined when generating the token, it's mandatory that you apply it using the following key: x-ah-openapi-app-key: [defined app key]
  • Adding x-ah-openapi-auth: openapi-token key in the header is mandatory as it indicates the token type.
The easiest way to build the Automation URL is by using the process_slug.
For example, if the process_slug is: process_slug": "onboarding-of-new-employee"
Then the URL for that automation is: https://{yourDomain}/automationhub_/process_slug/onboarding-of-new-employee
The request should look as in the following example:
Authorization: Bearer [Tenant ID/Token]
x-ah-openapi-auth: openapi-tokenContent-Type: application/json
  • Utilisez l'option Copier dans le presse-papiers (Copy to Clipboard) disponible après la colonne Jeton (Token) pour copier-coller votre valeur [ID de locataire/jeton (Tenant ID\Token)] à partir de votre page Ouvrir l'API (Open API) Automation Hub comme décrit dans la page Générer votre jeton (Generate your Token).
    docs image
  • If an App Key is included for your token, a Copy to Clipboard option becomes available after the App Key column. Use it to copy-paste your [App Key] value.
    docs image
Remarque :
Le [Jeton] requis pour passer des appels API Automation Hub a une validité limitée. S'il a expiré, modifiez la date d'expiration en accédant à l'option Actions (Actions) > Modifier (Edit) à partir de la colonne Action correspondant au jeton OU générez un nouveau jeton comme mentionné à la page Générer votre jeton (Generate your Token). Sinon, vous recevrez un code de statut 401.
