ai-center
Guía del usuario de AI Center
Automation CloudAutomation SuiteStandalone
Last updated 11 de nov. de 2024
Release date: 11 November 2024
Novedades
Note: The AI units dashboards are not available when connecting AI Center to an external standalone Orchestrator.
[Vista previa] Panel de información general sobre el consumo de unidades de IA
The licensing section of your organization and tenant admin views has been enhanced with the AI units consumption overview table. It is available on the Consumables tab, by selecting View Usage in the AI Units section. The AI units consumption overview dashboard breaks down the usage of AI units across tenants and regions.
Each tenant within the dashboard includes a link to the corresponding Insights dashboard, which provides detailed information on AI units consumption. For more information on how this is reflected in Insights, check out the Insights documentation.
[Vista previa] Panel de consumo de Document Understanding y AI Center
You can now track your Document Understanding and AI Center AI units consumption using an Insights dashboard. The dashboard provides a broken down view of AI units per product, project, project type, and automation.
Para obtener más información sobre cómo se refleja esto en Insights, consulta la documentación de Insights.
Problemas conocidos
Due to a wrong ai-proxy version, skill deployments can fail when using using AI Center connected to an external standalone Orchestrator.
To fix this, go to ArgoCD, then to aicenter/ai-proxy , and update the ai-proxy parameter with the following value: aicenter/ai-proxy:v24.10-11.07-rc02
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
© 2005-2024 UiPath. Todos los derechos reservados.
