- Notas relacionadas
- Antes de empezar
- Primeros pasos
- Acciones
- Procesos
Acciones Overview
The Overview tab of Action Center allows you to track Actions, through prebuilt dashboards that summarize the Actions created up to the last 30 days. These dashboards display information about:
Cuántas acciones están Pendientes, Completadas o Sin asignar, en un tiempo determinado, y en función de su tipo o prioridad.
El tiempo medio que se tarda en completar una acción.
Cómo gestiona sus acciones un usuario concreto, durante un periodo de tiempo determinado.
Cómo gestionan los usuarios sus acciones, en función del Catálogo de acciones al que pertenecen.
Vista Mis acciones
In the My Actions view, you can see the Actions that have been assigned to you.
Gestionar vista Acciones
In the Manage Actions view, you can see the Actions that have been assigned to all users. You can also see the actions of a specific user, inside the All users / Username view.
Pasar de una vista a otra
By default, the My Actions view is selected, which displays an overview of your Actions. If you want to view other users' Actions you can select the Manage Actions view.
You can have an overview of Actions, based on the action catalog to which they belong. The default selection for Action Catalog is All catalogs.
Hora de creación
You can have an overview of Actions, based on the time when the Actions were created. The default selection for Creation Time is Last Week.
Marcos de estado
Los cuadros de estado muestran el número de acciones para cada estado (Pendiente, Completado, Sin asignar).
Clicking a status frame redirects you to the Inbox tab and automatically filters Actions based on the respective Action status and the creation time.
Average completion time
In the My Actions view, the Avg. Completion Time frame shows the average time it takes you to complete an Action.
El periodo de finalización promedio se calcula en función de las acciones creadas, asignadas y completadas tras el lanzamiento de la característica Visión general de las acciones.
Status tabs
Las pestañas de estado muestran gráficos circulares de las acciones en función de tu estado: Pendiente, Completada y Sin asignar.
Cada pestaña de estado muestra:
- a pie chart showing Actions by Priority: Low, Medium, High, and Critical;
- a pie chart showing Actions by Type: Data Labeling, Document Classification, Document Validation, External, and Form.
Por prioridad
En función de la pestaña de estado en la que te encuentres, el gráfico circular Acciones por prioridad muestra el número total de acciones Pendientes, Completadas o Sin asignar y, a continuación, las organiza por prioridad.
Clicking a slice of the pie chart redirects you to the Inbox tab, where a list of actions with the corresponding filters (status, priority, creation time) is displayed.
Por tipo de acción
En función de la pestaña de estado en la que te encuentres, el gráfico circular Acciones por tipo muestra el número total de acciones Pendientes, Completadas o Sin asignar y, a continuación, las organiza por tipo.
Clicking a slice of the pie chart redirects you to the Inbox tab, where a list of actions with the corresponding filters (status, type, creation time) is displayed. # Average completion time(??)
Tabla Todos los usuarios
The All Users table offers an organized overview of the number of Actions that are Pending and Completed for each user, as well as the average time it takes each user to complete an Action.
Below is a description of the columns of the All Users table.
| Columna | Muestra |
| Nombre de usuario | El nombre del usuario. |
| Pendiente | El número de acciones que están pendientes para el usuario. |
| Completado | El número de acciones completadas por el usuario. |
| Tiempo promedio de finalización | El tiempo medio que tarda el usuario en completar una acción. El periodo de finalización promedio se calcula en función de las acciones creadas, asignadas y completadas tras el lanzamiento de la característica Visión general de las acciones. |
Puedes ordenar las columnas en orden ascendente o descendente. Clic
para ordenar una columna.
To find out more about how to use Actions overview , see the Working with Actions overview section.
