- Getting started
- Host administration
- Organizations
- Authentication and security
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Notifications
- Logging
- Troubleshooting
Automation Suite Admin Guide
Configuring system email notifications
Configure your host email settings so that you can send email notifications to users from a specified email address.
Notifications can be related to user accounts (password recovery), or be related to email alerts from other Automation Suite services, such as Orchestrator.
To configure email preferences, log in to the host portal as a system administrator, make sure that Host is selected on the left, and click Settings.
Field |
Description |
SMTP Host |
The IP or Domain of the SMTP server. |
SMTP Domain |
Domain for the username, if SMTP server requires authentication. |
SMTP Port |
The SMTP port. For example, if you are using a Gmail account to send mail messages and Enable secure connection is selected, the port should be 587. |
SMTP Username |
The username of the SMTP server, if it requires authentication. For example, if you are using Gmail, fill in this field with the email address to be used to send messages. You can leave this field blank if you want to use anonymous authentication. |
SMTP Password |
The password for the email account specified in SMTP Username. You can leave this field blank if you want to use anonymous authentication. |
Default From Address |
The email address from which to send system email messages. |
Default From Display Name |
A custom display name for the email address from which you send system notifications. |
80
and port 587
are opened for the machine (single node | multi-node).
Option |
Description |
Enable secure connection |
If enabled, the connection is secured and a TLS certificate is required for the SMTP domain you are using. If disabled, the connection is not secured. Note: Both port
587 and port 80 must be opened during installation for this setting to work.
