Automation Suite
- First Time Configuration
- Host Administration
- Organization Administration
- Accounts and Roles
- Licensing
Audit Logs for the Host Portal
Automation Suite Admin Guide
Last updated Mar 25, 2024
The audit logs from the host portal capture the main actions performed by system administrators so that you can track who changed what, and when.
To view the audit logs, sign in to the host portal as a system administrator, make sure that Host is selected at the top of the left pane, and then click Audit Logs.
Note: If you are still using the old admin experience, select Audit Logs from the options on the left instead.
This page lists the actions performed by system administrators strictly within the host portal.
Click at the right of a row to open the Audit Data dialog and see details for that log entry:
