- Getting started
- Host administration
- About the host level
- Managing system administrators
- Creating or Deleting Organizations
- Allocating host licenses to organizations
- Configuring System Email Notifications
- Audit logs for the host portal
- Organizations
- Authentication and security
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
This page describes how to license organizations from the host-level pool of licenses.
If you have a pool of user, robot, and service licenses at the host level, you can allocate a custom number of those licenses to your organizations, thus licensing those organizations.
After you allocate licenses to organizations, organization administrators can further allocate those licenses to the accounts and tenants in their organization, as needed.
- The instructions on this page are for system administrators and refer to license allocation at the host level. If you are an organization administrator, follow the instructions in the organization administration section of this guide to allocate licenses for your organization.
- The amount of time it takes for changes to license allocation for an organization to be propagated to the Orchestrator tenant and to AI Center is set by the
License.Cache.Expiration.Minutesparameter and it is set to 5 minutes by default. Do not change this setting to avoid causing configuration errors.
Allocating Licenses to Organizations
Log in to the host portal as a system administrator.
From the panel on the left, select the organization to which you want to allocate licenses, and then click Licenses.
Note:If you are still using the old admin experience, on the Organizations page, at the right end of an organization row, click Allocate Organization Licenses
Edit the values to allocate the required number of each type of license to the organization.
The number of licenses that you have available in the host license pool is shown on the right.
When you are done, click Save to allocate the licenses.
The allocated licenses are available within 5 minutes for the organization administrator to allocate them as needed in their organization.
Removing Host Licenses From an Organization
Doing this leaves the organization as unlicensed and unusable.
and select Remove License Allocation. -
In the confirmation dialog, click Remove to confirm the action.
All licenses that were previously allocated to the organization are returned to the host license pool within 5 minutes.
