Automation Suite API guide
  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Delete Robot Accounts
Deletes multiple robot accounts from an organization, based on the organization ID.
API Endpoint
DELETE https://{yourDomain}/{organizationName}/identity_/api/RobotAccount/{partitionGlobalId}
Scopes
Requires the following scopes:
  • PM.RobotAccount
  • PM.RobotAccount.Write
Request Headers
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
Note: To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Path Parameters
Path param
Data type
partitionGlobalId
(required)
String
The ID of the organization you want to retrieve the robot accounts for.
Request Body
The request body contains the list of robot accounts IDs you want to bulk delete from the organization.
     "robotAccountIDs": [
          "string",
          "string"
          "string",
          "string"
Responses
200 OK
The indicated robot accounts are deleted from the organization.
Example Request
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}/{tenantName}/
  • Your {access_token} is: 1234 (for length considerations).
  • The {partitionGlobalId} is: magic-7
  • The robot accounts you want to delete have the following IDs:
    • Bot1: 11-xy
    • Bot2: 22-tz
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/RobotAccount/magic-7' \
--data-raw '{
          "11-xy",
          "22-tz"
}'curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/RobotAccount/magic-7' \
--data-raw '{
          "11-xy",
          "22-tz"
  • API Endpoint
  • Scopes
  • Request Headers
  • Path Parameters
  • Request Body
  • Responses
  • 200 OK
  • Example Request
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
