Automation Hub API guide
- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
Automation ID input parameter for the GET Collaborators call, which retrieves all users assigned a collaborator role on a specific automation idea.
The GET Collaborators call allows users to retrieve all the users assigned with a collaborator role within a specific automation idea.
Note:
As an input parameter use the automation ID, in order to identify the Automation Idea for which you want to retrieve the list of collaborators.
| Key | Value | Use Case |
| collaborators | Automation ID | GET request parameter |
Example: collaborators=72 where 72 is the automation ID
UI Correspondent: Collaborators.
