Automation Hub API guide
Input for Collaborators
Input parameters for the GET Collaborators API call in Automation Hub 2.2510 on Automation Suite, using automation ID to retrieve assigned collaborators.
The GET Collaborators call allows users to retrieve all the users assigned with a collaborator role within a specific automation idea.
Note:
As an input parameter use the automation ID, in order to identify the Automation Idea for which you want to retrieve the list of collaborators.
KeyValueUse Case
collaboratorsAutomation IDGET request parameter
Example: collaborators=72 where 72 is the automation ID
UI Correspondent: Collaborators.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
