Automation Hub API Guide
Last updated Nov 11, 2024
Update Automation Idea Phase and Status
Use this call to easily keep your Idea phase and status updated. Below you can find an example of how to make a call in which the Idea phase is updated to status Assessment in Progress.
Post: https://{yourDomain}/automationhub_/api/v1/openapi/automations/status
Request
 Headers
	Authorization: Bearer [Tenant ID/Token]
  x-ah-openapi-auth: openapi-token
 data-raw '{
  "process_id": 1183,
  "phase_status_id": 53
 }'  Headers
 data-raw '{
  "process_id": 1183,
Response
    "message": "Resource Updated",
    "statusCode": 201,
    "data": {
        "message": "Sync Successful."
    "statusCode": 201,
    "data": {
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
