Automation Hub API guide
Input for Category
Category ID input rules for Automation Hub API calls, including how hierarchy chaining works using the lowest-level category ID.
Note:
Use the lowest Category ID in order for the whole hierarchy chain to be inputted.
KeyValueUse Case
hierarchyThe Category values are not defined as these fields are customized by each tenant.GET and POST request parameters
Note:
You can easily extract the Category values relevant for your tenant by using the GET category call.
Example: "category=717" where 717 is a level 3 Category used in order to input the whole Category chain (the Level 1 Category, the Level 2 Category, and the Level 3 Category).
UI Correspondent
  • Categories
  • UI Correspondent
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
